Link Nissan S15Link - #NS15X PlugIn ECU
SKU: NS15X
- £1,325.00
- £1,325.00
+ MVA (kun Storbritannia)
Designed for the SR20 engine. This ECU will work with the 64 pins, blue header plug ECU version.
ECU includes an onboard 4 bar MAP or 7 bar MAP sensor.
Suitable Applications:
S13 Silvia / 180SX SR20DET (but not CA18DET)
S14a Silvia (facelift) SR20DET
S15 Silvia SR20DET
S15 Silvia SR20DE
RNN14 Pulsar GTI-R SR20DET
N15 Pulsar SR16VE
N14 Distributed
*For the 76 pin header ECU, have a look at the S13X PlugIn listing.
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
Gnd Sensor Ground Only
DI6 Digital Input
DI7 Digital Input
An Volt 5 Analog 0-5V input
An Volt 6 Analog 0-5V input
Expansion connector 2
Ign 5 Ignition 5 Auxiliary output
Ign 6 Ignition 6 Auxiliary output
Ign 7 Ignition 7 Auxiliary output
DI 8 Digital Input
Volt 8 Analog 0-5V input
Volt 9 Analog 0-5V input
Volt 10 Analog 0-5V input
Volt 11 Analog 0-5V input
- G4X PlugIn ECU
- Stickers
S13 Silvia / 180SX SR20DET (but not CA18DET)S14a Silvia (facelift) SR20DET
S15 Silvia SR20DET
S15 Silvia SR20DE
N15 Pulsar SR16VE
N14 Distributed
CAN port
Staged injection
The following expansion connector inputs/outputs are provided:Expansion connector 1
DI6 Digital Input
DI7 Digital Input
DI 8 Digital Input
- G4X PlugIn ECU
- Stickers
