MV Agusta F3 & F4 AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-MV-V02569310-X47SOLO2DL02
- £710.00
- £710.00
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the MV Agusta this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide | MV Agusta ECU connection cable |
This kit has been specifically designed for MV Agusta bikes. The kit comes with a cable for your bike. Connecting the Solo 2 DL to your MV Agusta ECU will give you all the engine performance information you need to help improve your driving performance.
The plug & play cable currently fits the following MV Agusta bike models:
F3 675 - From 2012 | F3 800 - From 2012 |
F4 1000 - From 2013 |
The MV Agusta ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
- Display: Graphical
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
Below is the pinout drawing for the MV Agusta plug & play connection cable.
- Solo 2 DL
- Power cable with AC adapter
- User manual
- AiM MV Agusta Connection Cable
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the MV Agusta this kit will ensure an improvement in your driving performance.Key Features :
This kit has been specifically designed for MV Agusta bikes. The kit comes with a cable for your bike. Connecting the Solo 2 DL to your MV Agusta ECU will give you all the engine performance information you need to help improve your driving performance.Plug & Play
The MV Agusta ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated.
- GPS: 10 Hz
- Memory: 4 GB
- Solo 2 DL
- User manual
