Gå til produktinformasjon
1 av 2
Super B Nomada 12V105AH Lithium Traction Battery
SKU: SB-E-105
£1,240.00
£1,488.00
INC VAT - UK only
£1,240.00
£1,240.00
£1,488.00
INC VAT - UK only
£1,240.00
superb lithium batteries
The Nomada 12V105Ah is a modular Lithium Iron Phosphate (LiFePO4) rechargeable battery with a rated capacity of 105 Ah. This new addition to our portfolio of lithium batteries has a compact and lightweight modular design which means you can easily scale up your energy system. The Nomada is mainly designed for use as a system battery and not as a stand-alone battery.
The Nomada 12V105Ah-LT variant, with an internal heater, allows charging in ambient temperatures below 0°C. This model efficiently heats the Li-ion battery using its own energy. Through a well-designed system setup, the battery can be heated without depleting its charge. This eliminates the need for additional cables or heaters
  • Product Features
  • Modular traction battery
  • Lithium Iron Phosphate (LiFePO4): Safe Li-ion technology
  • Integrated BMS (Battery Management System),
  • BIB or BCI with disconnect device (relay) is required
  • PC+ABS (UL94 V-0) flame-retardant battery casing
  • Terminals for 2 x M8 bolts
  • External fuse needed
  • Wired communication interface: CANopen
  • Easy CAN bus interconnection
  • Battery monitoring and history storage
  • Adaptive cell balancing
  • Configurable in serial or parallel connection
  • Independent temperature sensor for DNV type approved battery
  • The optional LT model includes internal heating
Intended Use
The Nomada 12V105Ah Li-ion battery serves as an energy source of 12V in power systems for recreational vehicles, commercial vehicles, leisure boats, commercial vessels and stationary applications. Potential applications for this Li-ion battery include: off grid power supply, marine power supply, medium for (renewable) energy storage and (traction) battery for vehicles. Using it as a starter battery is not possible. Up to 4 batteries can be connected in series or in parallel to increase the total capacity up to 420Ah. When using more than 4 batteries in series or parallel always consult Super B.
PERFORMANCE
Low maintenance
Fast charging
Safest lithium technology
High discharge currents
High capacity
Low weight
High cycle count
Low self-discharge
NOMADA PARALLEL CONFIGURATION
NOMADA SERIES CONFIGURATION
CERTIFICATIONS
UN38.3 UN38.3 UN38.3 UN38.3 UN38.3 UN38.3
3 Year Warranty
A 3-year warranty offers the best peace of mind. It is the benefit of years of continuous engineering improvement and proven experience with all of our batteries in the harshest environments.
3 year warranty
When it comes to powering your electric vehicle or marine craft, the Super B Nomada 12v105ah Lithium Traction Battery is a top-of-the-line choice. This high-performance battery is designed to provide long-lasting power and reliability, making it ideal for a wide range of applications.
One of the key features of the Super B Nomada 12v105ah Lithium Traction Battery is its impressive energy density. This means that it is able to store a large amount of energy in a relatively compact package, making it perfect for use in vehicles where space is at a premium. With a capacity of 105 amp-hours, this battery is capable of delivering the power needed to keep your vehicle running smoothly for extended periods of time.
In addition to its energy density, the Super B Nomada 12v105ah Lithium Traction Battery is also known for its high level of efficiency. Unlike traditional lead-acid batteries, lithium batteries are able to deliver power consistently over their entire discharge cycle, without suffering from the voltage drop-off that can occur with other types of batteries. This means that you can rely on your Super B Battery for any event you enter into.
ELECTRICAL SPECIFICATIONS
Nominal capacity
105Ah
Open circuit voltage
13.2v
self-discharge
<3% per month
Cycle Life
>3500 cycles (at 100% DoD)
Voltage
12v
MECHANICAL SPECIFICATIONS
Dimensions (LxWxH)
437 x 90 x 175 mm / 17.2” x 3.5” x 6.9”
Weight
10 kg / 22 lbs
Case material
PC-ABS | UL94-V0
Ingress protection
IP66
Cell type / Chemistry
Prismatic - LiFePO4
Charge method
CCCV
Charge voltage
14.3V - 14.6V
Max. charge current
105A
End of discharge voltag
10V
Discharge current continuous
105A
Discharge pulse current
315A (30 sec)
TEMPERATURE SPECIFICATIONS
Charge temperature
0°C to 55°C / 32°F to 131°F
Discharge temperature
-20°C to 55°C / -4°F to 131°F
Storage temperature
-20°C to 45°C / -4°F to 113°F
COMPLIANCE SPECIFICATIONS
Certifications
CE, UKCA, FCC, UN 38.3, DNV, UL 1642 (Cells), UN ECE R10.06, EN/IEC 62619-62620 (ESTRIN)
Shipping classification
UN 3480
GENERAL SPECIFICATIONS
EAN-13
8718531361799
Battery designation
IFpP/36/130/195/ [1P4S]M/-20+55/90
Available to download Here
superb app
  • Product Features
Intended Use
PERFORMANCE
Low maintenance
Fast charging
High capacity
Low weight
High cycle count
Low self-discharge
CERTIFICATIONS
3 Year Warranty
A 3-year warranty offers the best peace of mind. It is the benefit of years of continuous engineering improvement and proven experience with all of our batteries in the harshest environments. 3 year warranty
When it comes to powering your electric vehicle or marine craft, the Super B Nomada 12v105ah Lithium Traction Battery is a top-of-the-line choice. This high-performance battery is designed to provide long-lasting power and reliability, making it ideal for a wide range of applications. One of the key features of the Super B Nomada 12v105ah Lithium Traction Battery is its impressive energy density. This means that it is able to store a large amount of energy in a relatively compact package, making it perfect for use in vehicles where space is at a premium. With a capacity of 105 amp-hours, this battery is capable of delivering the power needed to keep your vehicle running smoothly for extended periods of time. In addition to its energy density, the Super B Nomada 12v105ah Lithium Traction Battery is also known for its high level of efficiency. Unlike traditional lead-acid batteries, lithium batteries are able to deliver power consistently over their entire discharge cycle, without suffering from the voltage drop-off that can occur with other types of batteries. This means that you can rely on your Super B Battery for any event you enter into.
Specifications
Nominal capacity
105Ah
13.2v
self-discharge
<3% per month
Cycle Life
Voltage
12v
Dimensions (LxWxH)
Weight
10 kg / 22 lbs
Case material
PC-ABS | UL94-V0
Ingress protection
IP66
Prismatic - LiFePO4
Charge method
CCCV
Charge voltage
14.3V - 14.6V
Max. charge current
105A
10V
105A
315A (30 sec)
Charge temperature
Storage temperature
Certifications
UN 3480
EAN-13
8718531361799
Battery designation
Quickstart Guide
Mobile App
superb app
