Gå til produktinformasjon
1 av 4
Yamaha YZF-R6 (2004-2005) AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-YAM-4
£710.00
£710.00
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Yamaha YZF-R6 this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide Yamaha YZF-R6 ECU connection cable
This kit has been specifically designed for the Yamaha YZF-R6 bike. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Yamaha YZF-R6 ECU will give you all the engine performance information you need to help improve your driving performance.
Yamaha YZF-R6 (YEC included) - 2004-2005
The Yamaha YZF-R6 ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
Below is the pinout drawing of the Yamaha YZF-R6 plug & play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • AiM Yamaha YZF-R6 Connection Cable
  • Bracket
  • 2 spacers
  • 2 self-locking nuts M6
  • 4 washers M6
  • 2 self-locking nuts M4
  • 2 washers
  • 2 Allen screws with rounded head M6 x 60mm
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • Solo 2 DL
  • User manual
  • Bracket
  • 2 spacers
  • 4 washers M6
  • 2 washers
