Gå til produktinformasjon
1 av 4
AiM Brake Pressure Sensor M10 0-160 Bar
SKU: S-P-B-M10-160-X05PSA00160B10
£190.00
£190.00
+ MVA (kun Storbritannia)
Powered by Shopify Planet
The AiM M10 0-160 Bar pressure sensor is suitable for oil and fuel pressure readings and can read pressures up to 160 bars. This sensor will monitor brake pressure levels for optimum performance accurately.
M10 -  0-160 Bar 4 pins 719 male binder
The AIM M10 0-160 bar brake pressure sensors are fitted with male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers.
Whether your car is equipped with single, dual, fixed or adjustable master cylinders, adding brake pressure sensors allow you to monitor brake performance, make fundamental changes and identify issues quickly and precisely.
  • Supply: 8-16V
  • Characterisation: 500 mV/ 0 bar 4500 mV/ 160 bar
  • Consumption: < 10 mA
  • Sealing: IP66
  • Weight: 30g
  • Cable Length: 400mm
  • Thread: M10
  • AiM Brake Pressure Sensor M10 - 0-160 Bar
  • Supply: 8-16V
  • Sealing: IP66
  • Weight: 30g
  • Thread: M10
