Gå til produktinformasjon
1 av 4
AiM Brake Pressure Sensor M10 0-160 Bar
SKU: S-P-B-M10-160-X05PSA00160B10-K
£190.00
£190.00
+ MVA (kun Storbritannia)
Powered by Shopify Planet
AiM M10 0-160 bar pressure sensor suitable for brake pressure reading.
Key Features:
  • M10 0-160 bar
  • 4 pin binder 719 binder
  • Free race studio 3 download
M10 0-160 Bar Brake Pressure Sensor
AiM 0-160 M10 bar pressure sensor is suitable for brake pressure reading, being able to read pressures up to 160 bars.
Please Note: MXS / MXP / MXG / MXL (Strada and Pista) / MXL2 / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display/logger and the analogue sensor, please use the 719-719 extension lead which is available in various lengths from 0.5 - 3 metres. For most installations, you will need one of these leads.
AiM Technologies are committed to supplying, professional engineers with quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the marketplace today.
Unlock your potential
    • Supply: 8-16 V
    • Accuracy: <+/_ 0.5% FS (CLNH - combined non-linearity and hysteresis
    • Characterisation: 500mV / 0 bar
    • Consumption: 4500 mV / 5 bar
    • Sealing: IP66
    • Weight: 30g
    • Cable Length: 400mm
    • Thread: M10
    Key Features:
    • M10 0-160 bar
      • Supply: 8-16 V
      • Sealing: IP66
      • Weight: 30g
      • Thread: M10
      What's In The Box
