AiM EVO4 & EVO4S Download Lead
SKU: EVO4-DL
- £35.00
- £35.00
+ MVA (kun Storbritannia)
The AiM EVO4S cable is used to connect the EVO4/EVO4S data logger to a PC.
712 male binder - 3 pin | USB to PC connector |
Suitable for EVO4 - EVO4S |
The AiM EVO4S download lead is used to connect the EVO4/EVO4S data logger to a PC. It will enable data to be downloaded onto a PC and analysed with our Race Studio 3 software. Plug into the USB port on the EVO4S data logger.
With Race Studio 3 you can also analyse all data recorded by the EVO4S and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances.
- 712 male binder 3 pin
- Plug into the USB port on the data logger
- EVO4S Download Lead/USB Cable
The AiM EVO4S cable is used to connect the EVO4/EVO4S data logger to a PC.Key Features :
The AiM EVO4S download lead is used to connect the EVO4/EVO4S data logger to a PC. It will enable data to be downloaded onto a PC and analysed with our Race Studio 3 software. Plug into the USB port on the EVO4S data logger.Expand Your System
These are only some of the items that can be added to our EVO4S for incrementing the performance and the data acquired.Configure & Analyse with Race Studio 3
With Race Studio 3 you can also analyse all data recorded by the EVO4S and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances.Technical Specifications
