Gå til produktinformasjon
1 av 1
AiM LCU-One Lambda Controller Replacement Weld on Bung Kart
SKU: LCU-FR-K
£10.00
£10.00
The AiM steel LCU-One Lambda Controller replacement weld-on bung.
Replacement weld-on bung Steel Bung
The AiM weld-in bungs create a permanent, easy mount for your sensor fittings.
The female-threaded steel connectors feature a natural finish.
The weld-in bungs are beneficial for retrofitting and testing applications.
Optional Extras
The Bosch LSU 4.9 Probe designed to measure the proportion of oxygen in exhaust gases. Available in the Accessories Tab.
  • Weld-on Bung
  • 24.7mm (1.5mm)
  • x 1 Weld on Bung 24.7mm (1.5mm)
The female-threaded steel connectors feature a natural finish. The weld-in bungs are beneficial for retrofitting and testing applications.
Optional Extras
  • Weld-on Bung
  • 24.7mm (1.5mm)
