{"product_id":"aim-mxp-1-3-strada-iva-tft-kit-car-dash-display","title":"\u003ctc\u003eAim\u003c\/tc\u003e MXP 1.3 Strada IVA-kompatibel TFT-sett for bildashbord","description":"\u003cdiv id=\"shopify-section-template--18081099448422__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eIVA-kompatibel digital dashbordskjerm\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eIVA-kompatible skjermer er avgjørende for OEM-byggesettbiler og racerbiler som er lovlige for veien i Storbritannia, og sikrer samsvar med\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.gov.uk\/vehicle-approval\/individual-vehicle-approval\" title=\"IVA Standards\"\u003eStandarder for individuell kjøretøygodkjenning (IVA)\u003c\/a\u003e.\u003c\/p\u003e  \u003cp\u003eDisse digitale dashbordskjermene overholder lovlige standarder for trafikk, enkel plugging \u0026\u0026amp; play-installasjon og tilkobling til kit-bilens ECU for å forbedre ytelsen – alt mulig med den IVA-spesifikke andre ledningsnettet som følger med displaysettet.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18081099448422__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eHvorfor velge \u003ctc\u003eAim\u003c\/tc\u003e MXP IVA-kompatibelt dashborddisplaysett\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXP IVA-kompatible dashbord er en del av en rekke digitale skjermer, spesielt utviklet for kit-bilførere som trenger viktig datasynlighet mens de er på veien. De viser sanntidsdata som hastighet, turtall og temperaturer, men de inkluderer ikke dataloggingsfunksjoner innebygd. For å utvide mulighetene til å logge data på samme måte som loggere med fullskjerm, kreves et Strada Logger Kit.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18081099448422__rich_text_QU9Lb7\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eEnkel tilkobling\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXP 1.3 Strada IVA-skjermen er tilgjengelig med et utvalg av tilkoblinger. Velg enten OBDII eller K-Line CAN, avhengig av om du vil koble til kit-bilens ECU eller OBDII-port eller direkte til ECU-en via CAN-kanalen.\u003c\/p\u003e  \u003cp\u003eDu kan sample og vise dusinvis av kanaler direkte fra ECU-en med bare to kabeltilkoblinger til ECU-en i stedet for flere tilkoblinger til analoge sensorer. De samplede dataene avhenger av den faktiske ECU-en, men vil vanligvis inkludere turtall, gassposisjon, olje, luft, vanntemperatur, oljetrykk, batterispenning, hastighet, gir og lambdaverdi (luft\/drivstoff-forhold). Listen over tilgjengelige ECU-drivere er over 1000 og oppdateres kontinuerlig.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18081099448422__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDigitale utganger\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXP 1.3 Strada IVA-skjermen har en digital utgang på 1 AMP som kan konfigureres til å aktiveres\/deaktiveres avhengig av verdien på de analoge\/digitale inngangene eller impulsene fra ECU-en. Dette lar deg automatisk kjøre eksterne systemer, for eksempel å slå av\/på ekstra lys, for å aktivere\/deaktivere en kjølevifte eller sirkulasjonspumper når en bestemt hendelse inntreffer.\u003c\/p\u003e  \u003cp\u003eMed CAN-utgang kan du sende meldinger direkte til et eksisterende CAN-nettverk for å forbedre utvalget av muligheter for kjøretøykontroll.\u003c\/p\u003e  \u003cp\u003eTo analoge kamerainnganger er også tilgjengelige for å slå skjermen om til en\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-mirror-reversing-camera-for-mx-series-pdm\" title=\"Aim Mirror \u0026amp; Reversing Camera for MX Series \u0026amp; PDM\"\u003espeilkamera\u003c\/a\u003e, via en trykknappkommando eller hendelseshåndtering. Kameraet selges separat.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18081099448422__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eSkjerm med veiikoner\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXP 1.3 Strada IVA-kompatibelt dashbord har en 6\" TFT-fargeskjerm med høy kontrast. Den visuelle kvaliteten er optimalisert av omgivelseslyssensoren, som holder bakgrunnsbelysningen på best mulig lysstyrkenivå.\u003c\/p\u003e  \u003cp\u003eVeiikoner lar deg legge til betingelser for LED-ikonene, for eksempel drivstoff, motor, olje, lys, indikasjon og mer.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18081099448422__rich_text_nAJYLi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eForhåndskonfigurerte sider\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXP 1.3 Strada IVA-dashbordet viser turtallsskalaen og alle dataene du trenger, som hastighet, vanntemperatur og oljetrykk, rundetider og mye mer. Du kan tilpasse sider etter dine behov, inkludert opptil fire ekstra felt.Definer hvilke data som vises med skalaen på slutten og måleenhetene. Det er enkelt å bytte mellom sidene; bare bruk trykknappene.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18081099448422__rich_text_9enpXA\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eFleksibelt skiftlys \u0026og alarmer\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe 10 flerfargede RGB-skiftlysene og 5 alarm-RGB-ene kan tilpasses etter din smak, og definerer turtallsterskelen på analoge eller digitale innganger, ECU-verdier, utvidelsesverdier, matematiske kanaler eller valgfritt GPS-alternativ. Du kan velge forhold og farger, velge en solid arm eller en blinkende og blinkfrekvensen. Du kan også konfigurere en tilhørende tekstmelding og angi alarmprioriteter.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003ch3\u003e  \u003cbr\u003e\u003cbr\u003e  \u003c\/h3\u003e","brand":"AiM Car","offers":[{"title":"Default Title","offer_id":39443926777958,"sku":"MXP-IVA-CAN","price":1285.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_mxp_iva_00_d290d0b5-e58f-48a7-80d9-e051df0ae4fd.webp?v=1755096730","url":"https:\/\/www.aimshop.com\/no\/products\/aim-mxp-1-3-strada-iva-tft-kit-car-dash-display-no","provider":"AimShop.com","version":"1.0","type":"link"}
