{"product_id":"aim-mxs-strada-5-tft-motorcycle-dash-display-with-race-icons","title":"Aim MXS 1.3 Strada 5\" TFT Motorcycle Dash Display with Race Icons","description":"\u003cdiv id=\"shopify-section-template--17925961580646__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eHvorfor velge MXS Strada motorsykkeldashbordet\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXS Strada med løpsikoner er et av de mest brukte dashborddisplayene på baner rundt om i verden. MXS 1.3 Strada har en kompakt 5\" TFT-fargeskjerm som gir et flott visuelt inntrykk. Du kan konfigurere dashbordet til å vise all informasjon som kommer fra motorsykkelens ECU, analoge\/digitale innganger, forhåndsdefinerte matematiske kanaler og en valgfri GPS-modul.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17925961580646__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eEnkel tilkobling\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXS 1.3 Strada har et utvalg av ECU-tilkoblinger. Velg mellom OBDII eller K-Line CAN. Avhengig av om du vil koble til motorsykkelens ECU ved hjelp av OBDII-porten eller direkte til ECU-en via CAN-kanalen.\u003c\/p\u003e  \u003cp\u003eDet er enkelt å koble MXS 1.3 Strada-dashbordet til motorsykkelens styreenhet. Du kan sample og vise dusinvis av kanaler. Dette er vanligvis det raskeste og enkleste oppsettet, da du bare trenger to kabeltilkoblinger til styreenheten i stedet for flere tilkoblinger til analoge sensorer.\u003c\/p\u003e  \u003cp\u003eDe samplede dataene avhenger av den faktiske ECU-en, men vil vanligvis inkludere turtall, gassposisjon (TPS), olje, luft, vanntemperatur, oljetrykk, batterispenning, hastighet, gir og lambdaverdi (luft\/drivstoff-forhold). Listen over tilgjengelige ECU-drivere er over 1000 og oppdateres og oppgraderes kontinuerlig.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17925961580646__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDigitale utganger\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXS 1.3 Strada har en 1-AMP digital utgang som kan konfigureres til å aktiveres\/deaktiveres avhengig av verdien på de analoge\/digitale inngangene eller impulsene som kommer fra motorsykkelens ECU. Dette lar deg automatisk kjøre eksterne systemer, for eksempel å slå av\/på ekstralys, for å aktivere\/deaktivere en kjølevifte eller sirkulasjonspumper når en bestemt hendelse inntreffer.\u003c\/p\u003e  \u003cp\u003eMed CAN-utgang kan du sende meldinger direkte til et eksisterende CAN-nettverk for å forbedre utvalget av muligheter for kjøretøykontroll.\u003c\/p\u003e  \u003cp\u003eTo analoge kamerainnganger er også tilgjengelige for å slå skjermen om til en\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-mirror-reversing-camera-for-mx-series-pdm\" title=\"Aim Mirror \u0026amp; Reversing Camera for MX Series \u0026amp; PDM\"\u003espeilkamera\u003c\/a\u003e, via en trykknappkommando eller hendelseshåndtering. Kameraet selges separat.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17925961580646__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eSkjerm med løpsikoner\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXS 1.3 Strada har en 5\" TFT-fargeskjerm med høy kontrast. Den visuelle kvaliteten er optimalisert av omgivelseslyssensoren, som holder bakgrunnsbelysningen på best mulig lysstyrkenivå. Løpsikoner lar deg legge til betingelser for LED-ikonene.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17925961580646__rich_text_nAJYLi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eForhåndskonfigurerte sider\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXS 1.3 Strada viser turtallsskalaen og alle dataene du trenger, som hastighet, vanntemperatur og oljetrykk, rundetider og mye mer. Du kan tilpasse sider etter dine behov, inkludert opptil fire ekstra felt. Definer hvilke data som vises med skalaens slutt og måleenheter. Det er enkelt å bytte mellom sidene; bare bruk trykknappene.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17925961580646__rich_text_9enpXA\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eFleksibelt skiftlys \u0026og alarmer\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe 10 flerfargede RGB-skiftlysene kan tilpasses etter din smak, og definerer turtallsterskelen på analoge eller digitale innganger, ECU-verdier, utvidelsesverdier, matematiske kanaler eller valgfritt GPS-alternativ. Du kan velge forhold og farger, velge en solid arm eller en blinkende arm og blinkfrekvens. Du kan også konfigurere en tilhørende tekstmelding og angi alarmprioriteter.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003ch3\u003e  \u003cbr\u003e\u003cbr\u003e  \u003c\/h3\u003e","brand":"AiM Motorcycle","offers":[{"title":"Default Title","offer_id":43420711223398,"sku":"MXS-S","price":1030.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_mxs_strada_race_00_1fc8b2e9-1491-4b9f-b638-dc7d423df902.webp?v=1758637820","url":"https:\/\/www.aimshop.com\/no\/products\/aim-mxs-strada-5-tft-motorsykkel-dash-display-med-race-ikoner-1","provider":"AimShop.com","version":"1.0","type":"link"}
