{"product_id":"aim-mxs-strada-5-tft-sim-racing-dash-display","title":"\u003ctc\u003eAim\u003c\/tc\u003e MXS 1.3 Strada 5\" TFT Sim Racing Dash-skjerm","description":"\u003cdiv id=\"shopify-section-template--18137368854630__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eForbedre simulatorracingopplevelsen din\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003e5-tommers MXS 1.3 Strada simracing-dashbordet er en førsteklasses TFT-skjerm med høy kontrast, spesielt utviklet for simracingførere som krever det aller beste. Med tilpassbare RGB-skiftelys og profesjonell funksjonalitet bygger MXS simracing-dashbordet bro mellom spilling og ekte motorsportopplevelser.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18137368854630__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eHvorfor velge MXS Sim Racing Dash Display\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eSimracing har utviklet seg. Det er ikke lenger en hobby som er montert på kjøkkenbordet, men speiler nå profesjonaliteten til globale racingmesterskap, og kravene er høyere enn noensinne. Det er derfor både elbilførere og sjåfører i den virkelige verden stoler på den. \u003ctc\u003eAim\u003c\/tc\u003e, en datadrevet leder innen motorsportteknologi, for å levere de samme banebrytende verktøyene som brukes av racingteam i verdensklasse.\u003c\/p\u003e  \u003cul\u003e  \u003cli\u003eAnbefalt av motorsportteam i verdensklasse over hele verden.\u003c\/li\u003e  \u003cli\u003eBanebrytende teknologi tatt direkte fra banen til simulatoren din.\u003c\/li\u003e  \u003cli\u003eUovertruffen datanøyaktighet og visualisering for seriøse racerførere.\u003c\/li\u003e  \u003c\/ul\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18137368854630__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eKonfigurerbar skjerm\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMed den høykontrastfulle 5-tommers TFT-skjermen kan du konfigurere sider slik at de passer dine behov. Det digitale displayet lar deg også enkelt navigere gjennom sidene og velge mellom en rekke stiler, datatyper og måleenheter. En omgivelseslyssensor justerer bakgrunnsbelysningen for optimal lysstyrke, noe som sikrer klar sikt under alle lysforhold.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18137368854630__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eIntegrert Shift Light Array \u0026forsterker; LED-er\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMed integrerte girlys kan du velge mellom en rekke avanserte flerfargede RGB-girlysmønstre som kan tilpasses dine behov, og for hvert unike gir når det er nødvendig.\u003c\/p\u003e  \u003cp\u003eMXS Strada-skjermen har også seks RGB-LED-er, slik at du kan tilpasse farger, alarmtyper (fast eller blinkende), blinkfrekvens og tilhørende tekstmeldinger. Alarmprioriteter kan stilles inn etter dine spesifikke behov.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18137368854630__rich_text_nAJYLi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eAvansert dataanalyse med Race Studio 3\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eUtnytt kraften til \u003ctc\u003eAim\u003c\/tc\u003es gratis, profesjonelle programvare, Race Studio 3. Importer øktdataene dine og analyser hver runde med de samme verktøyene som ekte racinglag bruker. Identifiser styrker, finn feil og lås opp ytelsesforbedringer med uovertruffen presisjon, slik at du kan trene, konkurrere og forbedre deg som en proff.\u003c\/p\u003e  \u003cp\u003eVed å koble til via USB forvandler MXS Strada-skjermen simkortet ditt til et ekte \u003ctc\u003eAim\u003c\/tc\u003e dashbord. Få løpsdata i sanntid, rundetid og prediktiv rundetid vist rett foran deg – akkurat som i en ekte racerbil.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e","brand":"AiM Sim","offers":[{"title":"Default Title","offer_id":31824706142310,"sku":"MXS-S-SIM","price":1030.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_mxs_00_964ee2b8-776c-4cd2-8dc0-f25747d51251.webp?v=1758639977","url":"https:\/\/www.aimshop.com\/no\/products\/aim-mxs-strada-5-tft-sim-racing-dash-display-no","provider":"AimShop.com","version":"1.0","type":"link"}
