{"product_id":"aim-mxs-strada-light-5-tft-car-dash-display-with-race-icons","title":"\u003ctc\u003eAim\u003c\/tc\u003e MXS 1.3 Strada Light 5\" TFT-skjerm for bildashbord med løpsikoner","description":"\u003cdiv id=\"shopify-section-template--17924219994214__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003cdiv id=\"shopify-section-template--17924219994214__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eKompakt motorsportskjerm\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXS Strada med racingikoner er en av de mest brukte dashbordskjermene på baner rundt om i verden. Strada «Light»-versjonen er laget som et mer tilgjengelig produkt for folk som bruker færre analoge innganger og bare trenger en CAN-tilkobling for ECU-en sin.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17924219994214__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eHvorfor velge MXS 1.3 Strada lysdisplay\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eSelv om den er veldig lik MXS Strada, har MXS Strada Light fire fullt konfigurerbare analoge innganger (maks. 500 Hz hver) i stedet for de åtte som finnes på standard MXS Strada (maks. 1000 Hz hver). Den har heller ikke en digital utgang eller en RPM-tilkobling, som finnes i standard MXS Strada.\u003c\/p\u003e  \u003cp\u003eVelg enten OBDII eller K-Line CAN, avhengig av om du vil koble til kjøretøyets ECU eller OBDII-port eller direkte til ECU-en gjennom CAN-kanalen.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17924219994214__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eEnkel tilkobling\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDet er enkelt å koble MXS 1.3 Strada Light-dashbordet til ECU-en din. Du kan sample og vise dusinvis av kanaler direkte fra bilens ECU. Dette er vanligvis det raskeste og enkleste oppsettet, da du bare trenger to ledningstilkoblinger til ECU-en i stedet for flere tilkoblinger til analoge sensorer.\u003c\/p\u003e  \u003cp\u003eDe samplede dataene avhenger av den faktiske ECU-en, men vil vanligvis inkludere turtall, gassposisjon (TPS), olje, luft, vanntemperatur, oljetrykk, batterispenning, hastighet, gir og lambdaverdi (luft\/drivstoff-forhold). Listen over tilgjengelige ECU-drivere er over 1000 og oppdateres og oppgraderes kontinuerlig.\u003c\/p\u003e  \u003cp\u003eMed CAN-utgangen kan du sende meldinger direkte til et eksisterende CAN-nettverk for å forbedre kontrollmulighetene for kjøretøyet. To analoge kamerainnganger er også tilgjengelige for å slå skjermen om til en\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-mirror-reversing-camera-for-mx-series-pdm\" title=\"Aim Mirror \u0026amp; Reversing Camera for MX Series \u0026amp; PDM\"\u003espeilkamera\u003c\/a\u003e, via en trykknappkommando eller hendelseshåndtering. Kameraet selges separat.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17924219994214__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eSkjerm med løpsikoner\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXS 1.3 Strada Light har en kompakt 5\" TFT-fargeskjerm med høy kontrast. Den visuelle kvaliteten er optimalisert av omgivelseslyssensoren, som holder bakgrunnsbelysningen på best mulig lysstyrkenivå mens du er på banen. Løpsikoner lar deg legge til betingelser for LED-ikonene.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17924219994214__rich_text_nAJYLi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eForhåndskonfigurerte sider\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXS 1.3 Strada Light viser turtallsskalaen og alle dataene du trenger, som hastighet, vanntemperatur og oljetrykk, rundetider og mye mer. Du kan tilpasse sider etter dine behov, inkludert opptil fire ekstra felt, og du kan definere hvilke data som vises med skalaens slutt og måleenheter.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17924219994214__rich_text_9enpXA\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eFleksibelt skiftlys \u0026og alarmer\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe 10 flerfargede RGB-skiftlysene kan tilpasses etter din smak, og definerer turtallsterskelen på analoge eller digitale innganger, ECU-verdier, utvidelsesverdier, matematiske kanaler eller valgfritt GPS-alternativ. Du kan velge forhold og farger, velge en solid arm eller en blinkende, samt blinkfrekvensen. Du kan også konfigurere en tilhørende tekstmelding og angi alarmprioriteter.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e","brand":"AiM Car","offers":[{"title":"Default Title","offer_id":40138059055206,"sku":"MXS-S-L","price":885.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_MXSSTRADALIGHTRACE_00copy9_1.5x.webp?v=1757598270","url":"https:\/\/www.aimshop.com\/no\/products\/aim-mxs-strada-light-5-tft-car-dash-display-with-race-ikoner-1","provider":"AimShop.com","version":"1.0","type":"link"}
