{"product_id":"aim-mxt-strada-10-tft-car-dash-display-with-road-icons","title":"\u003ctc\u003eAim\u003c\/tc\u003e MXT 1.3 Strada 10\" TFT-skjerm i bilens dashbord med veiikoner","description":"\u003cdiv id=\"shopify-section-template--17918277386342__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eHvorfor velge MXT 1.3 Strada 10-tommers dashbordskjerm\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXT Strada med veiikoner er et av de mest brukte dashborddisplayene på veier rundt om i verden. MXT 1.3 Strada har en 10\" TFT-fargeskjerm som gir et flott visuelt inntrykk. Du kan konfigurere dashbordet til å vise all informasjon fra ECU-en, analoge\/digitale innganger, forhåndsdefinerte matematiske kanaler og en valgfri GPS-modul.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17918277386342__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eEnkel tilkobling\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXT 1.3 Strada er tilgjengelig med et utvalg av tilkoblinger. Velg enten OBDII eller K-Line CAN, avhengig av om du vil koble til bilens ECU eller OBDII-port eller direkte til ECU-en via CAN-kanalen.\u003c\/p\u003e  \u003cp\u003eDu kan sample og vise dusinvis av kanaler direkte fra bilens ECU med bare to kabeltilkoblinger til ECU-en i stedet for flere tilkoblinger til analoge sensorer. De samplede dataene avhenger av den faktiske ECU-en, men vil vanligvis inkludere turtall, gassposisjon (TPS), olje, luft, vanntemperatur, oljetrykk, batterispenning, hastighet, gir og lambdaverdi (luft\/drivstoff-forhold). Listen over tilgjengelige ECU-drivere er over 1000 og oppdateres kontinuerlig.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17918277386342__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDigitale utganger\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXT 1.3 Strada har 2 digitale utganger på 1A maks. som kan konfigureres til å aktiveres\/deaktiveres avhengig av verdien på de analoge\/digitale inngangene eller impulsene fra bilens ECU. Dette lar deg automatisk kjøre eksterne systemer, for eksempel å slå av\/på ekstralys, for å aktivere\/deaktivere en kjølevifte eller sirkulasjonspumper når en bestemt hendelse inntreffer.\u003c\/p\u003e  \u003cp\u003eMed CAN-utgang kan du sende meldinger direkte til et eksisterende CAN-nettverk for å forbedre utvalget av muligheter for kjøretøykontroll.\u003c\/p\u003e  \u003cp\u003eTo analoge kamerainnganger er også tilgjengelige for å slå skjermen om til en\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-mirror-reversing-camera-for-mx-series-pdm\" title=\"Aim Mirror \u0026amp; Reversing Camera for MX Series \u0026amp; PDM\"\u003espeilkamera\u003c\/a\u003e, via en trykknappkommando eller hendelseshåndtering. Kameraet selges separat.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17918277386342__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eSkjerm med veiikoner\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXT 1.3 Strada har en 10\" TFT-fargeskjerm med høy kontrast. Den visuelle kvaliteten er optimalisert av omgivelseslyssensoren, som holder bakgrunnsbelysningen på best mulig lysstyrkenivå.\u003c\/p\u003e  \u003cp\u003eVeiikoner lar deg legge til betingelser for LED-ikonene, for eksempel drivstoff, motor, olje, lys, indikasjon og mer.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17918277386342__rich_text_nAJYLi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eForhåndskonfigurerte sider\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXT 1.3 Strada viser turtallsskalaen og alle dataene du trenger, som hastighet, vanntemperatur og oljetrykk, rundetider og mye mer. Du kan tilpasse sider etter dine behov, inkludert opptil fire ekstra felt. Definer hvilke data som vises med skalaens slutt og måleenheter. Det er enkelt å bytte mellom sidene; bare bruk trykknappene.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17918277386342__rich_text_9enpXA\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eFleksibelt skiftlys \u0026og alarmer\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe 10 flerfargede RGB-skiftlysene kan tilpasses etter din smak, og definerer turtallsterskelen på analoge eller digitale innganger, ECU-verdier, utvidelsesverdier, matematiske kanaler eller valgfritt GPS-alternativ. Du kan velge forhold og farger, velge en solid arm eller en blinkende arm og blinkfrekvens. Du kan også konfigurere en tilhørende tekstmelding og angi alarmprioriteter.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003ch2 style=\"text-align: center;\"\u003e  \u003cbr\u003e\u003cbr\u003e  \u003c\/h2\u003e","brand":"AiM Car","offers":[{"title":"Default Title","offer_id":40297832513638,"sku":"MXT-S-I-CAN\/","price":1455.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_mxt_strada_road_00_10681841-a89b-495f-81f3-c480f2c52774.webp?v=1770643705","url":"https:\/\/www.aimshop.com\/no\/products\/aim-mxt-strada-10-tft-car-dash-display-with-road-ikoner-1","provider":"AimShop.com","version":"1.0","type":"link"}
