{"product_id":"aim-power-distribution-module-pdm32","title":"Aim Power Distribution Module PDM32","description":"\u003cdiv class=\"SCXW259150324 BCX0\"\u003e  \u003cdiv class=\"OutlineElement Ltr SCXW259150324 BCX0\"\u003e  \u003cdiv id=\"shopify-section-template--17864358068326__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eAvansert strømfordelingsmodul\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e PDM32 er en 32-kanals avansert strømfordelingsmodul som er utviklet for å drive en rekke kjøretøykretser, og fjerner behovet for tradisjonelle sikringsskap og reléer. Den gir et forenklet ledningsnett med økt pålitelighet og kontrollfunksjoner.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17864358068326__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eHvorfor velge PDM32\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003ePDM32 er tilgjengelig alene eller med et valg av 5\", 6\" eller 10\" dashbordskjermer. Den kan også motta data fra kjøretøyets ECU og inkluderer til og med en datalogger og GPS-modul for rundetidtaking og banekartlegging.\u003c\/p\u003e  \u003cp\u003eMed en total kontinuerlig maks. strøm på 120 A gir hver av utgangene tilbakemelding til dataloggeren for å gi viktig informasjon som åpne kretser, kortslutninger, høy\/lav spenning, antall feilmeldinger og tiden mellom meldingene er brukerdefinerbar. Alle utganger kan konfigureres som PWM-er for myk start\/stopp. Alle PDM-kretsene kan settes opp og overvåkes via Race Studio 3-programvaren.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17864358068326__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003ePDM32 Datahåndtering\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003ePDM32 kan motta og registrere data fra følgende kilder:\u003c\/p\u003e  \u003cul\u003e  \u003cli\u003eECU: Over 1000 protokoller tilgjengelig\u003c\/li\u003e  \u003cli\u003eDigitale\/analoge innganger\u003c\/li\u003e  \u003cli\u003eIntern 9-akset EMU\u003c\/li\u003e  \u003cli\u003eGPS: Rundetid og posisjon\u003c\/li\u003e  \u003cli\u003eUtvidelsesmoduler\u003c\/li\u003e  \u003cli\u003eTrykknapper fra RIO02 (fjernstyrt inngangs- og utgangsmodul) eller et hvilket som helst kommersielt CAN-tastatur\u003c\/li\u003e  \u003cli\u003ePDM-utganger: Strømmer og status for hver kanal individuelt\u003c\/li\u003e  \u003cli\u003eAndre brukerdefinerte mattekanaler\u003c\/li\u003e  \u003c\/ul\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17864358068326__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eUtvid systemet ditt\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eKombiner PDM-en din med en klype 5\", 6\" eller 10\",  2 kamerainnganger og en GPS-modul for rundetid og banekartlegging.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17864358068326__rich_text_nAJYLi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch3 class=\"heading title-sm\"\u003e\u003cstrong\u003eValgfrie ledningsløsninger\u003c\/strong\u003e\u003c\/h3\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eEN\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/collections\/power-distribution-module-cables-harness\" title=\"pre-assembled harness\"\u003eforhåndsmontert sele\u003c\/a\u003e\u003cspan\u003e  \u003c\/span\u003eer tilgjengelig for en enklere kablingsløsning, fargekodet og merket for å gi de enkleste installasjonene.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17864358068326__rich_text_MqT7z9\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch3 class=\"heading title-sm\"\u003e\u003cstrong\u003eGPS-alternativer\u003c\/strong\u003e\u003c\/h3\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/collections\/aim-gps-lap-timing\" title=\"GPS module\"\u003eGPS09-modulalternativ\u003c\/a\u003e\u003cspan\u003e  \u003c\/span\u003egir enkel rundetidtaking og rundeposisjon for banekartlegging. PDM-en har over 4000 racerbaner i databasen, så når du ankommer banen, kjenner systemet allerede tidtakingspunktene slik at du kan fortsette kjøringen.\u003c\/p\u003e  \u003cp\u003eGPS09-modulen er tilgjengelig med forskjellige ledningslengder for å passe til ulike bruksområder, og med kabelinngang fra undersiden (takversjon) eller siden.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17864358068326__rich_text_TMmMDz\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch3 class=\"heading title-sm\"\u003e\u003cstrong\u003eCAN-tastaturer\u003c\/strong\u003e\u003c\/h3\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eHa dine egne utvalgte knapper lett tilgjengelig og få kontroll over kjøretøyet ditt med en rekke\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/collections\/buttons-switches\" title=\"Keypads\"\u003etastaturer\u003c\/a\u003e.  Fra å bare slå på motoren, viftene eller blinklysene, til å skifte gir og mer, kan du programmere vårt utvalg av knapper på tastaturet for å sikre sømløs ytelse på veien eller banen.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e","brand":"AiM","offers":[{"title":"Default Title","offer_id":39364695195750,"sku":"PDM-32","price":1460.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product__name__00_9307efdf-87a9-476f-821d-724e78783d1b.webp?v=1757603659","url":"https:\/\/www.aimshop.com\/no\/products\/aim-power-distribution-module-pdm32","provider":"AimShop.com","version":"1.0","type":"link"}
