{"product_id":"aim-shift-light-module","title":"Aim Shift Light Module","description":"\u003cdiv id=\"shopify-section-template--18033684578406__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eKompakt skiftlysmodul\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e Shift Light Module er et kompakt sett med 10 RGB-LED-lys som hjelper til med å overvåke turtallsterskler, varsler og andre indikatorer, slik at du får full kontroll over optimale turtall på girspaken.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18033684578406__rich_text_z3LwRp\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eHvorfor velge \u003ctc\u003eAim\u003c\/tc\u003e Shift Light-modul\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDu kan enkelt stille inn LED-fargen og turtallsverdien som slår hver LED av\/på, avhengig av girnummeret. Girlysmodulen er ideell når du har en logger, men ikke et dashborddisplay, eller hvis dashborddisplayet er plassert der du ikke lett kan se girlysene.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18033684578406__rich_text_9xFbAA\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eForbindelse\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eShift Light-modulen bruker en CAN-tilkobling, som er en 712-712 hann 5-pinners patchledning. Disse selges separat og er tilgjengelige i 0,5 og 2 m. Du kan velge hvilket som helst av alternativene ovenfor.\u003c\/p\u003e  \u003cp\u003eDen kan brukes med MX dash-serien, både Logger- og Strada-versjoner, samt med PDM-skjermer.\u003c\/p\u003e  \u003cp\u003e\u003cem is=\"\" class=\"highlighted-text inline-block not-italic relative animate\" data-style=\"text\"\u003e\u003cstrong\u003eNote\u003c\/strong\u003e\u003c\/em\u003eDu trenger patchledningen for å aktivere tilkobling til dashbordskjermen eller loggeren.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18033684578406__rich_text_73pLyj\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003ePrediktiv rundetidtaker\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eShift Light Module kan også stilles inn som en prediktiv rundetidtaker ved hjelp av Race Studio 3-programvaren vår. Tilpass LED-linjen til å bli grønn hvis du forbedrer kronologien din sammenlignet med den beste i økten, eller den kan bli rød hvis du blir dårligere.\u003c\/p\u003e  \u003cp\u003e\u003cstrong\u003eVennligst merk\u003c\/strong\u003eFunksjonen for prediktiv rundetid er kun tilgjengelig for MX-serien av dashbordskjermer.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e","brand":"AiM Accessories","offers":[{"title":"Default Title","offer_id":32278309568614,"sku":"SLM","price":170.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_shiftlight_01copy2_1.5x.webp?v=1757687943","url":"https:\/\/www.aimshop.com\/no\/products\/aim-shift-light-module","provider":"AimShop.com","version":"1.0","type":"link"}
