Gå til produktinformasjon
1 av 1
AiM Smartycam GP HD Rev 2.2 Bullet Camera Motorcycle
SKU: SM-CAM-W-GP-XB1SGPH22B12L201
£920.00
£920.00
+ MVA (kun Storbritannia)
All deliveries are carbon neutral
Powered by Shopify Planet
Capture. Replay. Overlay. Analyse.
Full HD recording. Crystal Clear Video. 240x320 pixels. TFT Colour display. Automatic Start/Stop. Real-time HD videos. Configurable. Choice of lens. Waterproof.
The AiM SmartyCam GP HD 2.2 has been engineered to provide great videos and overlay all the technical data you want to see to help improve your performance whilst racing. The SmartyCam GP HD is used worldwide, giving racers and track day drivers fantastic high definition, high frame rate videos with all the data to help improve your performance. It's easy to install, robust, reliable and can withstand the extreme working conditions expected by the track.
The SmartyCam GP HD 2.2 has a wide TFT colour display. Intelligent settings allow the camera to automatically start/stop recording by using the inbuilt 3 axis accelerometer, so you can concentrate on the track and not the camera, and immediate playback helps with setting up.
The Bullet camera is robust and lightweight making it easy to install to the inside or outside of your car.  The connection cable from the recorder box to the bullet has been engineered to be strong and ensure connectivity. We have a wide range of brackets available to suit your requirements.
Direct CAN Connection
The SmartyCam GP HD has been designed to integrate the direct connection to the CAN-bus line of the ECU and it will allow using the can-bus communication protocols included in our official database or manage the customized can-bus protocols.
This feature has been designed particularly for vehicles where the available space is minimal.
Integrated CAN bus Hub
The SmartyCam GP HD has four connectors, one completely dedicated to the bullet cam, one for the ECU-MIC, one for the GPS Module connection and EXP to connect with AiM dash/logger.
Real-Time Overlay
SmartyCam GP HD (Rev 2.2) automatically overlays on your video all of the data you need: speed, RPM, lap number, gear shifts and much more. Simply choose the data and graphical layout you prefer from the many different overlays available. Data can be read from all possible sources, from the GPS: track map and vehicle position as well as speed, lap and split times or from the AIM logger/dash logger connected to your ECU: RPM, throttle, engaged gear, acceleration, temperatures, pressures etc.
CMOS Sensor & Lens
SmartyCam GP HD 2.2 has been designed to avoid the problem of image distortion with the global shutter CMOS sensor. The camera shutter captures the entire image at the same time, the result is the images are captured at once and are not affected by the vibrations that happen while driving your car on the track or road which create the so-called wave effect.
The SmartyCam GP HD 2.2 is available with a choice of three lens options:
The narrow 67° HFOV lens, wide 84° HFOV lens, wide 120° HFOV lens.
Designed for extreme conditions
The SmartyCam GP HD has been designed to last and work under the pressure of extreme motorsport conditions such as poor weather, strong and prolonged vibrations, continuous rain and extreme high and low temperatures. The SmartyCam HD is made from machinery moulded aluminium.
When you're at the starting grid the last thing you want to be doing is setting up your camera. The SmartyCam HD has been designed with this in mind and switches on/off automatically and starts/stops recording in the same way.
The SmartyCam HD can be switched on by the logger it is connected to. Switch-off is automatic too, you decide after what period of non-activity the camera will switch off.
Higher Storage Capacity
 Using a compression system that has been optimised to provide the perfect balance between video quality and file size. Video is stored on an SD card and you can select 3 different recording quality options: High quality, 1 hour = 4GB, Standard quality - 1 hour = 2GB, Low quality - 1 hour = 1.5GB. This means that with a 128GB SD card you can store over 32 hours of footage.
The USB port and SD card housing are 100% protected from air and weathering.
SD cards are sold separately.
Expand your system
The SmartyCam GP HD 2.2 can be connected through the CAN network to our AiM Loggers, MX Series, MXL2, MyChron, Solo2 DL, EVO5, GPS Module and external microphone.
You can connect more SmartyCam HD cameras on the same CAN network. The SmartyCam has it's own configuration and automatically retrieves the data it needs from the network, without interfering with the others. You can also synchronize your video and data by the Loggers using Race Studio 3 software.
With Race Studio 3 you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You will also be able to manage your racing tracks and compare two laps watching the video recorded by SmartyCam HD cameras.
With Race Studio 3 you can also analyse all data recorded by the SmartyCam and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.
  • Video Format: H.264 1280 x 720 pixels @ 30 fps
  • Lens: Teleecentric with 6 elements
  • Field Of View: 67°, 84°, 120°
  • Internal Battery: Rechargeable Lithium Battery 1,500mAh
  • Battery Charge: 700 mAh 12V
  • Internal Battery Duration: 60 - 70 min of recording
  • External Power: 9-15V
  • Memory Capability:
  • 1.5 GB (1-hour low-quality recording)
  • 2 GB (1-hour medium quality recording)
  • 4 GB (1-hour high-quality recording)
  • Accelerometer: Three-axial + 5G
  • Usage Temperatures: -10°C/+60°C
  • Auto Power ON: Yes, if connected to an AiM Logger
  • Auto Power OFF: Yes
  • Body: Anodized Aluminium
  • Dimensions: Main unit 104.6 x 79.6 x 26.6 mm
  • Bullet Camera 24 diam x 48.2 mm
  • Connectors: 3 Binder 712 female connectors + 1SMA female connector
  • Bullet Cable Length: Choice of 2m or 4m
  • Weight: Main Unit 320g - Bullet 45g
  • Waterproof: IP67
      • SmartyCam GP HD 2.2
      • External CAN cable 2m or 4m
      • External power cable
      • User manual
Real-Time Overlay
CMOS Sensor & Lens
Expand your system
  • Waterproof: IP67
      • User manual
