AiM SmartyCam HD 2.1 & SmartyCam 3 Suction Cup Mount Motorcycle
SKU: SM-WM-X90KSSMC1
- £60.00
- £60.00
The SmartyCam can be installed using the suction cup mount. It is suitable for SmartyCam HD 2.1 & SmartyCam 3.
Quick and easy to secure | Mounts to a windscreen or flat surface |
Easy to move between vehicles | For SmartyCam HD 2.1 & SmartyCam 3 |
The suction cup mount for the AiM Smartycam is adjustable and holds securely to your windscreen, window or any other flat surface such as a motorcycle fuel tank.
Mounting your SmartyCam is quick and easy. It can be easily positioned as to not get in the driver's way.
Please Note: This bracket is only suitable for the SmartyCam HD 2.1 & SmartyCam 3
Suction Cup Mount
Securely attaches to any of your windscreens.
Includes all the fixture and fittings.
- Arm height 160mm ( 6.30 inches)
- 1 suction cup
- Clamp base with ball
- 160mm single ball arm
- 1 ball head
- 1 washer diameter 17.7mm, thickness 1.5mm, hole 6mm
The SmartyCam can be installed using the suction cup mount. It is suitable for SmartyCam HD 2.1 & SmartyCam 3.Key Features :
The suction cup mount for the AiM Smartycam is adjustable and holds securely to your windscreen, window or any other flat surface such as a motorcycle fuel tank.Mounting your SmartyCam is quick and easy. It can be easily positioned as to not get in the driver's way.
Suction Cup Mount
A solid ball and socket type system for optimum positioning.Securely attaches to any of your windscreens.
- 1 suction cup
- 1 ball head
