Gå til produktinformasjon
1 av 4
AiM SmartyCam HD / GP HD 2.1 + 2.2 External Power Cable & 3.5mm Female Jack Plug for External Microphone Harness
SKU: SM-EP-EM2
£80.00
£80.00
AiM SmartyCam HD / GP HD, External Power & 3.5 Jack
External power lead to allow battery connection 12v.
Key Features:
  • Improved sound
  • 712 7-pin binder
  • 3.5mm female jack plug
  • Constant 12v power supply
AiM SmartyCam HD / GP HD External Power Harness
The AiM SmartyCam HD / GP HD eternal power harness with an integrated 3.5mm female jack is a useful accessory for when you want the reassurance of having the camera powered from your vehicle's 12v system.
Use the 3.5mm female jack connection to connect this to an onboard radio or intercom system (additional cable may be required depending on your radio/intercom).
Allows the SmartyCam to be connected to an external battery for longer running times
712 male 7-pin connection
2 or 4 metres in length cable
12v
AiM Technologies are committed to supplying professional engineers with quality products. Our cables and accessories are well engineered and designed for rigours Motorsport. Our racing components are amongst the best in the industry today.
Unlock your potential
Technical sheet
Key Features:
  • Improved sound
  • 712 7-pin binder
The AiM SmartyCam HD / GP HD eternal power harness with an integrated 3.5mm female jack is a useful accessory for when you want the reassurance of having the camera powered from your vehicle's 12v system. Use the 3.5mm female jack connection to connect this to an onboard radio or intercom system (additional cable may be required depending on your radio/intercom).
12v
Technical sheet
