AiM Solo, Solo 2, Solo 2 DL Roll Bar Mount (V Bracket)
SKU: SOLO-VB
- £67.00
- £67.00
+ MVA (kun Storbritannia)
The AiM Roll Bar mount is suitable to be clamped to a roll bar, railing or tube. Used to secure for Solo GPS lap timer to your car.
Secure mounting for GPS lap timer | Ball & socket for positioning |
Suitable for Solo, Solo 2 & Solo 2 DL | |
Roll Bar Mount for GPS Lap Timer
The AiM Roll Bar Mount (V Bracket) is suitable for the Solo, Solo 2 and Solo 2 DL GPS Lap Timers.
It is used to securely mount the Solo, Solo 2 and Solo 2 DL GPS Lap timers to your car. The V bracket adjusts using a ball and socket type system for optimum positioning and simply clamps to a roll bar, railing or tube.
The duel swivel joint makes the viewing angle adjustment quick and easy and the securing clip has a rubber lining to prevent slipping and any vibrations affecting the display.
- 90mm arm
- Rollbar bracket
- Clamp base with ball
- Locknut
- 4.5cm and 5.5cm tube clamp
- Gasket
- Screws and washers
- 1 Roll Bar Mount Bracket for Solo, Solo 2, Solo 2 DL
The AiM Roll Bar mount is suitable to be clamped to a roll bar, railing or tube. Used to secure for Solo GPS lap timer to your car.Key Features :
The AiM Roll Bar Mount (V Bracket) is suitable for the Solo, Solo 2 and Solo 2 DL GPS Lap Timers.It is used to securely mount the Solo, Solo 2 and Solo 2 DL GPS Lap timers to your car. The V bracket adjusts using a ball and socket type system for optimum positioning and simply clamps to a roll bar, railing or tube.
- 90mm arm
- Rollbar bracket
- Locknut
- Gasket
