AiM Strada 1.1 14 Pin OBDII Harness for MXS, MXP, MXG
SKU: MXS-S-L-OBDII
- £95.00
- £95.00
+ MVA (kun Storbritannia)
AiM 1.1 Model Strada 14 Pin OBDII Connector
AiM MXS, MXG, MXP Connector Harness. 1.1 for older model dashes.
Key Features:
14 Pin Connection Harness
The AiM 14-pin connector for older model dashes. The wiring harness is a standard replacement for the MXS, MXG, and MXS (MX Strada Series) dash displays. Ideal if you are transferring the dash to a different vehicle or if the original harness/ loom has been damaged. Please Note: 1.1 version is for older model dashes only |
Unlock your potential |
AiM Strada 14 Pin OBDII Harness for MXS, MXG, MXP
AiM Strada 14 Pin OBDII Harness for MXS, MXP, MXG
Key Features:
14 Pin Connection HarnessThe AiM 14-pin connector for older model dashes. The wiring harness is a standard replacement for the MXS, MXG, and MXS (MX Strada Series) dash displays. Ideal if you are transferring the dash to a different vehicle or if the original harness/ loom has been damaged. Please Note: 1.1 version is for older model dashes only
Whats In The Box
