Gå til produktinformasjon
1 av 1
Aim Strada IVA Vehicle Integration Loom MXS, MXP, MXG
SKU: MX-S-VIL
£195.00
£195.00
The Aim pre-wired Strada 23 pin IVA Integration loom is a dedicated wiring loom to integrate with our IVA dash displays, offering a simple installation to your vehicle's electrics.
Key Features:
23 pin pre-wired loom Additional speed sensor
Fits MX Series Perfect for kit car builders
The Aim Strada 23 pin IVA loom with a wheel speed sensor is a dedicated wiring loom made to integrate with the IVA dash displays. The loom will offer a simple installation for your vehicle's electrics.
Allowing the perfect solution for kit car builders, the system will allow you to monitor:
All ECU information and Odometer
Oil Temperature
Engine Temperature
Fuel Levels
Side Lights
Hazards
Front Fog
Rear Fog
Parking Brake
Main Beam
Dipped Beam
LH Indicator
RH Indicator
A fuel level sender can work with the Aim Channel Expansion unit with a suitable patch lead.
The IVA loom has a pull-up resistor incorporated, which is unnecessary with the fuel level sender and can cause inconsistent readings.
  • Strada IVA 23 pin Integration Loom
  • Wheel Speed Sensor
  • Wire Code:
  • Channel 1 - Yellow - Fuel Level
  • Channel 2 - Green - Engine Temperature
  • Channel 3 - Violet - Oil Pressure
  • Channel 4 - Orange & Brown - RH Indicator & LH Indicator
  • Channel 5 - Blue - Main Beam
  • Channel 6 - White - Dipped Beam
  • Channel 7 - Grey - Side Lights
  • Channel 8 - Pink - Rear Fog Light
  • Black - RPM
  • Blue-Brown-Black - Wheel Speed Sensor
  • 1 X 23 pin IVA Strada Integration Loom with Wheel Speed Sensor
Key Features:
Allowing the perfect solution for kit car builders, the system will allow you to monitor: All ECU information and Odometer
Oil Temperature
Engine Temperature
Fuel Levels
Side Lights
Hazards
Front Fog
Rear Fog
Parking Brake
Main Beam
Dipped Beam
LH Indicator
RH Indicator A fuel level sender can work with the Aim Channel Expansion unit with a suitable patch lead. The IVA loom has a pull-up resistor incorporated, which is unnecessary with the fuel level sender and can cause inconsistent readings.
  • Wire Code:
  • Black - RPM
