Gå til produktinformasjon
1 av 1
AiM Water/Oil Temperature Sensor PT100 M10 Thermo Resistor Motorcycle
SKU: S-T-M10
£70.00
£70.00
AiM Water/Oil Temperature Sensor M10 Thermo Resistor
The AiM PT100 M10 Thermo resistor temperature sensor is suitable for reading water and oil temperatures.
Suitable for water/oil temperature 4 pins 719 male binder
PT100 - M10
Sensor cable length 25cm
  • Temperature working range: 0/150°C
  • Cable sensor length: 250mm
  • M10 Thermo resistor
  • 4 pins male 719 Binder connection
  • 2kΩ 1% resistor between pins 1 and 4
  • AiM Water/Oil Temperature Sensor M10 Thermo Resistor
PT100 - M10
