{"product_id":"aim-sw4-280-formula-steering-wheel","title":"\u003ctc\u003eAim\u003c\/tc\u003e SW4 280 Formel ratt","description":"\u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_bCFQLY\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eDatalogging av ratt\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e Formula Steering Wheel 4 270\/280 er blant våre mest avanserte motorsportratt til dags dato. Det har en intern datalogger med komplett konfigurasjon, avtakbare håndtak, dreiebrytere og en lang liste med fullt kompatible ECU- og CAN-tilkoblingsalternativer.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_3kEhi6\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eHvorfor velge \u003ctc\u003eAim\u003c\/tc\u003e 270\/280 ratt\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e Formula-rattet 270\/280 er spesielt utviklet for profesjonelle motorsportapplikasjoner. Den interne dataloggeren er fullt konfigurerbar og er utviklet for å innhente og vise data fra ECU-en, med over 1000 fullt kompatible ECU-protokoller.\u003c\/p\u003e  \u003cp\u003eFormula-hjulene våre kommer i en rekke størrelser (270, 280,\u003cspan\u003e  \u003c\/span\u003e\u003ca title=\"Aim SW4 GT320\/GT350 Formula Steering Wheel\" href=\"https:\/\/www.aimshop.com\/products\/aim-sw4-gt320-gt350-formula-steering-wheel\"\u003eGT320 \u0026amp; GT350\u003c\/a\u003eDe kompakte 270- og 280-versjonene er det ideelle valget for ensetere eller sportsprototyper der plassen i cockpiten er begrenset. Forskjellen mellom Formula-rattet 4 270 og 280 er den totale diameteren: 280-en er 10 mm større for å passe til ulike førerpreferanser.\u003c\/p\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e SW4 270\/280 Formula-rattet er også fullt kompatibelt med vår PDM32 via CAN-kommunikasjon.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_cy4Jzy\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eEnkel tilkobling\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eKobler til \u003ctc\u003eAim\u003c\/tc\u003e Det er enkelt å koble 270\/280 Formula-rattet til ECU-en din. Du kan sample dusinvis av kanaler direkte fra ECU-en ved hjelp av én enkelt tilkobling, i stedet for å installere flere analoge sensorer.\u003c\/p\u003e  \u003cp\u003eDataene som samples avhenger av hvilken ECU som er i bruk, men inkluderer vanligvis turtall, motorbelastning, gassposisjon (TPS), olje-, luft- og vanntemperaturer, oljetrykk, batterispenning, hastighet, gir og lambdaverdier (luft\/drivstoff-forhold). Listen over tilgjengelige ECU-drivere oppdateres og oppgraderes kontinuerlig, og inkluderer over 1000 forskjellige ECU-er.\u003c\/p\u003e  \u003cp\u003eMed CAN-utgang kan du sende meldinger direkte til et eksisterende CAN-nettverk, noe som muliggjør utvidet integrasjon med andre kjøretøysystemer.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_E8RKHy\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eUtstilling \u0026amp; Trykknapper\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e Formelrattet 4 270\/280 er utstyrt med høykontrast 4.3\" TFT-skjerm, fullt konfigurerbar og synlig i sollys. Med 8 skiftlys, 4 RGB-alarm-LED-er og en integrert omgivelseslyssensor gir rattet klar, presis og pålitelig informasjon direkte til føreren til enhver tid.\u003c\/p\u003e  \u003cp\u003eFormula-rattet 4 270\/280 har 10 trykknapper og 3 dreiebrytere, alle bakgrunnsbelyst med RGB-LED-er. Det inkluderer også avtakbare håndtak, dreiebrytere og et bredt utvalg av ECU- og CAN-tilkoblingsmuligheter.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_nAJYLi\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eFleksible alarmer\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e SW4 270\/280 Formula-rattet har 8 konfigurerbare RGB-LED-lys for girskift og 4 konfigurerbare RGB-LED-lys for alarm. Du kan definere tilstander, farger, prioriteter og blinkfrekvenser, samt vise tilhørende tekstmeldinger når det er nødvendig.\u003c\/p\u003e  \u003cp\u003eDe avanserte RGB-girlysene i flere farger kan tilpasses fullt ut, med mulighet for å definere forskjellige girmønstre for hvert gir.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"shopify-section tab-controlled-section is-visible initial-reveal\" id=\"shopify-section-template--18113279262822__rich_text_9enpXA\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eEkstrautstyr\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDet finnes et bredt utvalg av tilbehør for å få mest mulig ut av rattet ditt:\u003c\/p\u003e  \u003cul\u003e  \u003cli\u003e  \u003ca title=\"Aim GPS09 Module\" href=\"https:\/\/www.aimshop.com\/products\/aim-gps09-gps-module\"\u003e\u003cstrong\u003eGPS-modul\u003c\/strong\u003e\u003c\/a\u003e:  GPS-modulen er koblet til via CAN og gjør det enkelt å måle rundetid og sporposisjon.\u003c\/li\u003e  \u003cli\u003e  \u003cstrong\u003eClutchpadler\u003c\/strong\u003e:  Venstre\/høyre clutchpadler kan legges til fra tilbehøret øverst på siden for å tilpasse den til din kjørestil.\u003c\/li\u003e  \u003cli\u003e  \u003cstrong\u003eAndre utvidelser\u003c\/strong\u003e:  Utvid systemet ditt med en rekke tillegg \u003ctc\u003eAim\u003c\/tc\u003e enheter, inkludert TC Hub, Lambda Controller, SmartyCam 3, RIO, GS-Dash og mer.\u003c\/li\u003e  \u003c\/ul\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cp\u003e270 mm Delenummer: X07SW42700\u003c\/p\u003e  \u003cp\u003e280 mm Delenummer: X07SW42800\u003c\/p\u003e","brand":"AiM Car","offers":[{"title":"Default Title","offer_id":42989426016358,"sku":"FSW4-280","price":2400.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_sw4270_280_03.webp?v=1779266414","url":"https:\/\/www.aimshop.com\/no\/products\/mal-sw4-280-formel-ratt-1","provider":"AimShop.com","version":"1.0","type":"link"}
