{"product_id":"aim-sw4-280-sim-racing-formula-steering-wheel","title":"\u003ctc\u003eAim\u003c\/tc\u003e SW4 280 Sim Racing Formelratt","description":"\u003cdiv id=\"shopify-section-template--18120943861862__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eDatalogging av ratt\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e 270\/280 Formel ratt 4 (SW4) er et av våre mest avanserte simulator-racingratt til dags dato. Formula-rattet inkluderer en intern datalogger med fulle konfigurasjonsalternativer, avtakbare håndtak, roterende brytere og fleksibel programvareintegrasjon med simulert telemetri.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18120943861862__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eHvorfor velge 270\/280 Formula-rattet\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e Formula-rattet 270\/280 er spesielt utviklet for simulatorkjørere. Den interne dataloggeren er fullt konfigurerbar og er designet for å samle inn og vise telemetridata direkte fra simulatorprogramvaren din. Med støtte for et bredt spekter av simulatorer og telemetriprotokoller er det et utmerket valg for kompakte cockpitinstallasjoner der plassen er begrenset.\u003c\/p\u003e  \u003cp\u003eVåre Formula-ratt kommer i en rekke størrelser (270, 280,\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-sw4-gt320-gt350-sim-racing-formula-steering-wheel\" title=\"Aim SW4 GT320\/GT350 Sim Racing Formula Steering Wheel\"\u003eGT320 \u0026amp; GT350\u003c\/a\u003e). Forskjellen mellom Formel SW4 270 og 280 er den totale størrelsen på rattet. Formula-rattet 280 er 10 mm større for å møte alle sjåførers behov.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18120943861862__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eEnkel tilkobling\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eKobler til \u003ctc\u003eAim\u003c\/tc\u003e Det er enkelt å koble 270\/280 Formel-rattet til racingsimulatoren din. Telemetri mottas direkte fra simulatorprogramvaren, noe som betyr at du kan sample dusinvis av kanaler uten å trenge fysiske sensorer.\u003c\/p\u003e  \u003cp\u003eAvhengig av racingsimulatoren inkluderer tilgjengelige data vanligvis turtall, gassposisjon, bremsetrykk, gir, hastighet, drivstoffnivå, dekkdata, rundetider og mer. Telemetrikompatibilitet oppdateres og utvides kontinuerlig, med støtte for mange av de mest populære racingsimulatorene.\u003c\/p\u003e  \u003cp\u003eMed CAN-utgang kan du sende meldinger til andre \u003ctc\u003eAim\u003c\/tc\u003e sim-racingenheter eller utvidelser, som utvider cockpitens utvalg av telemetri- og kontrollalternativer.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18120943861862__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eUtstilling \u0026amp; Knapper\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003e270\/280 Formelsimulator-racingrattet har høy kontrast 4.3\" TFT-skjerm som er fullt konfigurerbar og lett å lese under alle forhold. Med omgivelseslyssensoren justerer skjermen automatisk lysstyrken for å holde den klar og komfortabel.\u003c\/p\u003e  \u003cp\u003eFormula-rattet har også 10 trykknapper og 3 dreiebrytere, alle bakgrunnsbelyst med RGB-LED-lys for forbedret brukervennlighet i simulatorracingbilen din.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18120943861862__rich_text_nAJYLi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eFleksible alarmer\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e 270\/280 sim racing Formula-rattet har 8 konfigurerbare RGB-LED-er for girlys og 4 konfigurerbare RGB-LED-er for alarm. Du kan velge forhold og farger, enten de skal lyse kontinuerlig eller blinke, blinkfrekvenser og vise meldinger på skjermen ved siden av dem.\u003c\/p\u003e  \u003cp\u003eMed integrerte girlys kan du velge mellom en rekke avanserte flerfargede RGB-girlysmønstre som du kan tilpasse etter dine behov, og til og med konfigurere dem per gir.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18120943861862__rich_text_9enpXA\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eEkstrautstyr\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDet finnes et bredt utvalg av tilbehør for å få mest mulig ut av rattet ditt:\u003c\/p\u003e  \u003cul\u003e  \u003cli\u003e  \u003cstrong\u003eClutchpadler\u003c\/strong\u003e:  Vi tilbyr et clutchpadlesett med nedre venstre og høyre padle, eller de kan kjøpes separat som enten venstre eller høyre. Se alternativene øverst på siden for å kjøpe din.\u003c\/li\u003e  \u003cli\u003e  \u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-gps09-gps-module\" title=\"Aim GPS09 Module\"\u003e\u003cstrong\u003eGPS-modul\u003c\/strong\u003e\u003c\/a\u003e:  Når GPS-modulen brukes i simulatormiljøer, muliggjør den beregning av rundetid og analyse av virtuell baneposisjon, med en database med tusenvis av baner tilgjengelig.\u003c\/li\u003e  \u003c\/ul\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cp\u003e270 mm Delenummer: X07SW42700\u003c\/p\u003e  \u003cp\u003e280 mm Delenummer: X07SW42800\u003c\/p\u003e","brand":"AiM Sim","offers":[{"title":"Default Title","offer_id":43332277895270,"sku":"FSW4-280","price":2400.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_sw4270_280_03_059d26bd-9970-4336-9fc5-8ba1659364ca.webp?v=1779266476","url":"https:\/\/www.aimshop.com\/no\/products\/mal-sw4-280-sim-racing-formel-ratt-1","provider":"AimShop.com","version":"1.0","type":"link"}
