Gå til produktinformasjon
1 av 6
Peugeot Sport 208 Rally4 Aim SmartyCam 3 Dual Kit from 2020
SKU: Peugeot-SM3-D
£1,480.00
£1,480.00
Enhance your Peugeot Sport 208 Rally4's performance with the AiM SmartyCam 3 Dual Kit, specifically designed for models from 2020. Engineered for any racer who wants to get the most out of any performance video on the track, the SmartyCam 3 Dual is the flagship version of SmartyCam 3 range.
Dual Full HD camera system, Video output, CAN connection, USB-C connection, Ethernet port are only few of the features of SmartyCam 3 Dual: the most powerful of our range.
The new SmartyCam 3 Dual saves all your information to a supported SD card for up to 2TB of data, this includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the new SmartyCam 3 Dual automatically powers on and off in-sync with your engine – and will start/stop recording for you. Analyse your data from a vast range of sources such as GPS track map, vehicle position and speed, lap & split times. Video format is at H.264 1920x1080 pixels, 60 FPS, and the display resolution of 2.4” 240x320 pixels gives your footage crisp condition.
Our quality doesn’t falter, even under the pressure of extreme motorsport conditions such as poor weather, strong vibrations, continuous rain, and high/low temperatures as extreme as -10°C to + 50°C. Our camera is also waterproof (IP65) for extra protection.
hyundai i20 Rally2 BC3n
Supported Models and years
  • Peugeot Sport 208 Rally4
    from 2020
Peugeot Sport 208 Rally4 features a bus communication protocol based on CAN that can be reached through the 4 ways ITT Cannon female connector labelled GIP and located on the central tunnel.
smartycam icon
Video Output/Streaming
SmartyCam 3 Dual features a video output with SD interface. It allows you to send the video/audio directly to wherever you choose, for example your pit crew, at 30 or 60fps.
Two Video Inputs
Picture in Picture
smartycam icon
With the built-in data logger, you can view all the channels displayed on the video footage and review them with our new Race Studio 3 analysis software. Such channels include RPM, throttle, engaged gears, acceleration, temperatures, and pressures including a tri-axis accelerometer measuring 16G.
smartycam icon
Standalone Feature
The SmartyCam 3 Dual provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however, we have also equipped the SmartyCam 3 Dual with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the Dual through the CAN/ECU connections of your choosing.
smartycam icon
Quality
smartycam icon
Anatomy
smartycam icon
Higher Storage Capacity
Generic HD cameras focus too much on pixel numbers resulting in large file sizes. The SmartyCam 3 footage has the same quality as other FHD cameras with smaller files due to H.264 compression system parameters being optimised to a perfect balance between video quality and file size. Choose between three file quality levels: One hour recording = 4GB (High Quality), 2GB (Normal Quality) or 1.5GB (Lower quality).
SD cards sold separately.
smartycam icon
The SmartyCam 3 Dual Kit seamlessly integrates with the Peugeot Sport 208 Rally4's ECU, providing real time data overlays for enhanced performance analysis. The SmartyCam 3 Dual can be connected through the CAN network to our AiM Loggers, MX Series, MXL2, MyChron, Solo2 DL, EVO5 and ECU Bridge.
smartycam icon
Upgrade your Peugeot Sport 208 Rally4 with the AiM SmartyCam 3 Dual Kit today and experience unparalleled data insights for yourself!
  • CMOS sensor: Global Shutter
  • Video Out: 3G-SDI
  • External power: 9-15 Volt
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Body: Anodised Aluminium
  • Waterproof: IP65-rated to withstand the rigours of motorsport, this kit offers durability and reliability for Peugeot Sport 208 Rally4 drivers
smarty cam 3 sport connectors
smartycam3 dual pinout
Channels received by AiM devices configured with Peugeot Sport 208 Rally4 protocol are:
Channel Name Function
RPM Engine RPM
Car Speed Vehicle Speed
Wheel Speed FL Wheel Speed front left
Wheel Speed FR Wheel speed front right
Wheel Speed RL Wheel speed rear left
Wheel Speed RR Wheel speed rear right
rPedal Throttle pedal position
PBrake Front Brake pressure front
PBrake Rear Brake pressure rear
aSteering Steering wheel angle
Gear Engaged gear
Water Temp Engine coolant temperature
Oil Temp Engine oil temperature
Air Temp Intake air temperature
Ambient Temp AMbient temperature
Oil Press Engine oil pressure
Boost Boost pressure
  • SmartyCam 3 Dual
  • External Power Cable
  • USB-C Cable
  • 2 Bullet Cameras
  • 2 Co Ax Cables
  • Complete CAN / RS232 & Expantion With Ethernet Connection & External Mic Harness
    from 2020
smartycam icon
Two Video Inputs
Picture in Picture
smartycam icon
smartycam icon
Standalone Feature
smartycam icon
Quality
smartycam icon
Anatomy
smartycam icon
smartycam icon
smartycam icon
Technical Specifications
  • Video Out: 3G-SDI
Peugeot Sport 208 Rally4 Protocol
RPM Engine RPM
Gear Engaged gear
What's In The Box
  • SmartyCam 3 Dual
  • USB-C Cable
  • 2 Bullet Cameras
  • 2 Co Ax Cables
