{"product_id":"second-life-gps08-module-roof-mounted","title":"Second-Life GPS09-modul","description":"\u003cdiv id=\"shopify-section-template--18365841473638__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003ePresis GPS-sporing\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMed GPS09-programvaren kan du umiddelbart ta opptak av mellomtider, samt hastighet, posisjon og akselerasjon – alt dette er nødvendig for å forbedre kjøreprestasjonene og teknikken din. Oppdag over 4000 baner over hele verden og tilpass samlingene.\u003c\/p\u003e  \u003cp\u003eGPS09 aktiverer umiddelbar runderegistrering, og gjenkjenner start-\/mållinjer og detaljer uten problemer.\u003cspan\u003e  \u003c\/span\u003e\u003cem is=\"\" class=\"highlighted-text inline-block not-italic relative animate\" data-style=\"text\"\u003e\u003cstrong\u003eVennligst merk\u003c\/strong\u003e\u003c\/em\u003e:  GPS09 har ingen treghetsplattform.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18365841473638__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eHvorfor velge \u003ctc\u003eAim\u003c\/tc\u003e GPS09-modul\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e GPS09-modulen garanterer presisjon og pålitelighet, og samarbeider med nesten 20 satellitter for å forbedre ytelsen.\u003c\/p\u003e  \u003cp\u003eMed en gjennomsnittlig toleranse på under en halv meter bestemmer GPS09-modulens absolutte presisjon kjøretøyets nøyaktige posisjon. Satellittsignalet bruker raskt låste øyeblikk etter at enheten er slått på, og det er ingen risiko for manglende signaler på grunn av støy eller forstyrrelser i systemet.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18365841473638__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003ePå banen\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eGPS-modulen er rask til å innhente satellittsignaler og pålitelig i ugunstige situasjoner. GPS Manager lar deg angi start-\/mållinjer og delstreker for sporet, og laste ned en omfattende spordatabase. Med GPS09-modulen får du viktig informasjon, i.e.  chassisanalyse, baneposisjon osv., samt posisjon, hastighet, svinging i linje og lateral G og automatiske rundetider.\u003c\/p\u003e  \u003cp\u003eMed en tilgjengelig punkt-til-punkt-modus kan du maksimere presisjonen i rallyetappene for overlegen svinging. Denne modusen er utviklet for å øke kontrollen og manøvrerbarheten, og forbedre den generelle kjøreopplevelsen gjennom utfordrende etapper. Med punkt-til-punkt-modus blir hver sving en mulighet til å vise frem ferdigheter og finesse på banen.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--18365841473638__rich_text_ixKjaX\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDelta, prediktiv, splitt \u0026amp; Teoretiske tider\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe \u003ctc\u003eAim\u003c\/tc\u003e GPS09-modulen gir sanntidsinnsikt i runder for topp racingytelse. Registrer runde- og mellomtider med omfattende telemetri under baneøkter, og optimaliser basert på teoretiske beste runder for handlingsrettet innsikt når det er nødvendig.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e","brand":"Second-Life","offers":[{"title":"Default Title","offer_id":47051484921958,"sku":"5212096","price":230.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/GPS08RM.png?v=1788509288","url":"https:\/\/www.aimshop.com\/no\/products\/second-life-gps08-module-roof-mounted","provider":"AimShop.com","version":"1.0","type":"link"}
