Gå til produktinformasjon
1 av 2
Suzuki GSX-R 600, 750, 1000, GSX-R 1000 L7 AiM Solo 2 DL Motorcycle Cable & Bracket
SKU: SUZ-PP-SUZ-B
£163.00
£163.00
The AiM Suzuki motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.
Suzuki cable & bracket 7 pin - 712 male binder connection
Bracket suitable for Solo 2 & Solo 2 DL
Suzuki Solo 2 DL Cable & Bracket
The AiM ECU plug & play cable has been specifically designed for the Suzuki bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.
The AiM Suzuki bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
Please Note: Please see below for bracket information for your bike.
GSX-R600 - 2006-2019 GSX-R750 - 2006-2019
GSX-R1000 - 2005-2019 GSX-R1300 Hayabusa Gen.2 - 2008-2016
GSX-R1000 L7 - 2017 onwards
The Solo 2 & Solo 2 DL installation brackets are available for the following bike models/years:
GSX-R600 - 2001-2019 GSX-R750 - 2001-2019
GSX-R1000 - 2001-2004 and 2009-2019
Please Note: Not all product combinations are possible. Solo 2 DL installation brackets are not available for Suzuki GSX-R 1000 from 2005-2008, or GSX-R 1300 Hayabusa.2 from 2008-2016. Please contact one of the AiM support team for further information.
Example data protocols
  • Specifically designed Suzuki Plug & play cable and bracket for the Solo 2 DL
  • Below is the pinout drawing for the Suzuki plug & play connection cable.
  • Suzuki plug & play connection cable
  • 1 bracket
  • 1 toothed washer
  • 1 rubber dowel
The AiM ECU plug & play cable has been specifically designed for the Suzuki bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged. The AiM Suzuki bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike. Our brackets are supplied with all the necessary hardware required for fitting to your bike. Please Note: Please see below for bracket information for your bike. Also, If you are unsure this bracket will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.
Example data protocols sampled include RPM, Active gear, Vehicle speed, Front wheel speed, Rear wheel speed warning led, Engine coolant temperature, Brake pressure, Throttle position, Speed, ABS intervention, ALC intervention, Low fuel level, Traction control, Oil pressure, Map menu and many more. Refer to the technical sheet in the Downloads Tab for an extensive protocol list. Please Note: For these models/years Aim recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls.
  • 1 bracket
  • 1 toothed washer
  • 1 rubber dowel
