    Yamaha YZF-R6 2004-2005 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable - AimShop.com
    YAM-4-PP
    Yamaha YZF-R6 2004-2005 Aim Solo 2 DL & EVO4S Logger Plug & Play Cable
    In stock, ready to ship
    £60.00
    £60.00
    The AiM ECU plug & play cable has been specifically designed for Yamaha bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger.
    With a 7-pin 712 male binder connection.
    Yamaha plug & play cable 7 pin - 712 male binder connection
    Yamaha Plug & Play ECU Cable
    The AiM ECU plug & play cable has been specifically designed for the Yamaha bike. This plug & play cable can be used for the Solo 2 DL and the EVO4S Data Logger.
    Yamaha YZF-R6 (YEC included) - 2004-2005
    Example data protocols
    • Below is a pinout drawing for the Yamaha Solo 2 DL and EVO4S Data Logger plug & play connection cable
    • Yamaha YZF-R6 Plug & Play connection cable
    Technical sheet Race Studio 3
