1 z 3
AiM Exhaust Gas Thermocouple Temperature Sensor M5 with TC Yellow - 712 3 Pin Patch Lead
SKU: S-T-EGT-P-P-712-TC-15-3
Normalna cena
£110.00
Normalna cena
Cena sprzedaży
£110.00
AiM Exhaust Gas Thermocouple Temperature Sensor M5 K Type
The AiM Exhaust Gas Temperature Sensor (EGT) can measure the exhaust gas temperature by being placed in the exhaust header pipe. This sensor comes with a TC Yellow  - 712 3 pin patch lead 1.5m.
Measure exhaust gas temperature Thermocouple male fitting
Wide temperature range TC Yellow-712 3 pin patch lead
This sensor also comes with a TC Yellow  - 712 3 pin patch lead 1.5m in length.
Temperature range of 0-1000°C
Sensor cable length 25cm
  • Temperature working range: 0-1000°C
  • Cable sensor length: 25cm
  • Cable Type: Compensated
  • Two-pin male thermocouple connection
  • K Type thermocouple
  • TC Yellow to 712 3 pin patch lead 1.5m
  • AiM Exhaust Gas Thermocouple M5 Sensor (EGT)
It can measure the exhaust gas temperature by being placed in the exhaust header pipe around 150mm from the exhaust pipe. This sensor also comes with a TC Yellow  - 712 3 pin patch lead 1.5m in length.
MyChron4/5 S 2T Sensors are connected to the dash using the single patch lead (supplied with the dash), which splits into 2. Spare sensors are advisable to have as a spare or to have fitted to a 2nd race engine.  To use the sensors with an AiM MyChron expansion or EVO4 and EVO4S data loggers, you will need a 712 four-pin patch lead or to use them with an AIM TC Hub or directly to a MyChron4 or MyChron5 kart lap timer/dash logger. You will need a 712 three-pin patch lead.
