1 z 4
AiM MXP 1.3 Strada Suzuki IVA Compliant 6" TFT Display Plug & Play Kit
SKU: MXP-S-SUZ-KIT
Normalna cena
£1,075.00
Normalna cena
Cena sprzedaży
£1,075.00
CAN output Configure data
The dash comes with a  23 pin loom which has pre-configured connections for all the relevant electrical items in your vehicle such as oil. temperature, engine temperature, fuel level, sidelights, hazards, front and rear fog, handbrake, main beam, dipped beam and left and right-hand indicator. A speed sensor is also included in the kit to connect to this additional loom.
Digital Outputs
Pre-configured Pages
Flexible Shift Light & Alarms
Camera Inputs
  • Display: 6" TFT
  • CAN Connections: 3
  • Second CAN: Yes
  • Body: Anodized Aluminium
  • Pushbuttons: Metallic
  • Power Consumption: 400 mA
  • Weight: 590g
  • MXP Strada
  • 23 IVA Loom
  • Wheel Speed Sensor
Digital Outputs
The MXP features two digital outputs. The two digital outputs (Dout) are the LOW SIDE type (switch to ground). They can be configured in order to be turned on/off depending on the value of the analogue or digital inputs. They permit to automatically run external systems. For example, switch on/off additional lights, to activate/deactivate a cooling fan or circulation pumps when a certain event happens. With CAN Output you can send messages directly to an existing CAN network to improve the range of vehicle control possibilities.
Camera Inputs
  • Display: 6" TFT
  • Second CAN: Yes
  • Weight: 590g
  • MXP Strada
  • 23 IVA Loom
