1 z 2
AiM Water (Coolant) M10 Temperature Sensor Kart
SKU: S-T-M10-K
Normalna cena
£70.00
Normalna cena
Cena sprzedaży
£70.00
The AiM M10 water temperature sensor for MyChron can measure and sample water temperature providing accurate readings.
M10 water temperature sensor 4 pin 719 male binder connection
Suitable for all MyChrons Rotax, X30, OK Engines
The AiM PT100 M10 water (coolant) temperature kart sensor is for use with all MyChron kart dash/data loggers (including the new MyChron5 S and the older generation MyChron4). The sensor can measure and sample water temperature providing the most accurate readings.
The Thermo resistor should be in the cooling system/oil sump. It is recommended to install the sensor away from heat and electromagnetic interference sources like the RPM or Lap Receiver cables.
Temperature range of 0-150°C
Sensor cable length 250mm
The M10 thread is most commonly found on Rotax, X30 and OK engines
The sensors are sold with a 25cm cable and optional patch leads are available. MyChron 5 will require a 712-719 3 pin patch lead.
The MyChron 5 S 2T, will require the MyChron 2T patch lead TC plug & black 719 TR plug. All patch leads can be found in the accessories tab.
  • Temperature working range: 0/150°C
  • Cable Sensor Length: 250mm
  • M10 thread
  • 4 pin male 719 Binder connection
  • AiM Water Temperature Sensor M10 Thermocouple Resister
The AiM PT100 M10 water (coolant) temperature kart sensor is for use with all MyChron kart dash/data loggers (including the new MyChron5 S and the older generation MyChron4). The sensor can measure and sample water temperature providing the most accurate readings. The Thermo resistor should be in the cooling system/oil sump. It is recommended to install the sensor away from heat and electromagnetic interference sources like the RPM or Lap Receiver cables.
The sensors are sold with a 25cm cable and optional patch leads are available. MyChron 5 will require a 712-719 3 pin patch lead. The MyChron 5 S 2T, will require the MyChron 2T patch lead TC plug & black 719 TR plug. All patch leads can be found in the accessories tab.
  • M10 thread
