{"product_id":"aim-solo-2-dl-obdii-external-power-connector-cable","title":"Aim Solo 2 DL OBDII External Power Connector Cable","description":"\u003ch3\u003eAim Solo 2 DL OBDII \u0026amp; External Power Connector Cable\u003c\/h3\u003e\n\u003cp\u003eThe Aim OBDII 2m external power cable connects your Solo 2 DL to your ECU wiring.\u003c\/p\u003e\n\u003ch4\u003eKey Features :\u003c\/h4\u003e\n\u003ctable class=\"AimProductDescriptionTable\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003e7 pin - 712 male binder connection\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003eOBDII connector \u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd class=\"AimCell\"\u003eSuitable for Solo 2 DL\u003c\/td\u003e\n\u003ctd class=\"AimCell\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003ctr\u003e\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch3\u003eOBDII External Power Cable\u003c\/h3\u003e\n\u003cp\u003eThe Aim OBDII 2m external power cable is used to make your Aim device, Solo 2 DL communicate with the vehicle ECU.\u003c\/p\u003e\n\u003cp\u003eThis is one of the connection cables available for the Solo 2 DL. Others are the RS232\/CAN and the RPM cable.\u003c\/p\u003e\n\u003cp\u003eSome of the OBDII protocol channels received are RPM, Vehicle speed, Fuel level, Throttle position. For an extended list of protocols please see the technical data sheet in the Downloads Tab.\u003c\/p\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ch3\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/AiM_Solo_2_Connection_Example.png?v=1614780014\" style=\"width: 100%;\"\u003e\u003c\/h3\u003e\n\u003ch3\u003eExpand Your System\u003c\/h3\u003e\n\u003cp\u003eThese are some of the items that can be added to your car for incrementing performance and data.\u003c\/p\u003e\n\u003ch4\u003e\u003cbr\u003e\u003c\/h4\u003e\n\u003chr class=\"ProductDescription\"\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/www.aimshop.com\/pages\/aim-academy\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Aim_Webinars.png?v=1629297376\" alt=\"Visit Aim Academy\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Tech_Support_Icon_PD.png?v=1614590248\" alt=\"Visit Aim Tech Support\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003ctd\u003e\u003ca href=\"https:\/\/support.aimshop.com\/software\/downloads\" target=\"_blank\"\u003e \u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Download_Software_Icon_PD.png?v=1614590248\" alt=\"Download Race Studio Software\"\u003e \u003c\/a\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e\n\u003ch5\u003eTechnical\u003c\/h5\u003e\n\u003ch3\u003eAim Solo 2 DL OBDII \u0026amp; External Power Connector Cable\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e7 pin - 712 male binder connection\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e2m Cable\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e\u003cstrong\u003eOBDII Connector Pin:\u003c\/strong\u003e\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e2 - Positive bus line - SAE J1850 protocol: \u003cstrong\u003enot supported by Aim devices\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e4 - Chassis GND\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e5 - GND signal\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e6 - CAN High - ISO 15765-4 and SAE J2234 protocols\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e7 -  K-Line - ISO 9141-2 and ISO 14230-4 protocols\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e10 - Negative bus line - SAE J18050 protocol: \u003cstrong\u003enot supported by Aim devices\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e14 - CAN low - ISO 15765 and SAE J2234 protocols\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e15 - L line - ISO 9141-2 and ISO 14230-4 protocols\u003c\/li\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003e16 - Battery supply\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch5\u003eWhat's in The Box\u003c\/h5\u003e\n\u003ch3\u003eAim Solo 2 DL OBDII \u0026amp; External Power Connector Cable\u003c\/h3\u003e\n\u003cul class=\"AimProductDescriptionList\"\u003e\n\u003cli class=\"AimProductDescriptionList\"\u003eSolo 2 DL OBDII \u0026amp; External power cable connector\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eDownloads\u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ctable border=\"0\" cellpadding=\"10\" cellspacing=\"10\" style=\"width: 100%;\"\u003e\n\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca title=\"OBDII Technical Sheet\" href=\"https:\/\/www.aimtechnologies.com\/support\/faq\/OBDII_104_eng.pdf\" target=\"_blank\"\u003e \u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Technical_Sheet_Icon_AiM_100x100.png?v=1590766935\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003e\u003cspan class=\"AimProductDownloadsIcons\"\u003e\u003cimg src=\"https:\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/Race_Studio_3_Aim_Icon_1ddc4bc7-b4e7-4819-b550-99b4a90fddd6_100x100.png?v=1590782389\" alt=\"\"\u003e\u003c\/span\u003e\u003c\/a\u003e\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca title=\"OBDII Technical Sheet\" href=\"https:\/\/www.aimtechnologies.com\/support\/faq\/OBDII_104_eng.pdf\" target=\"_blank\"\u003eTechnical sheet\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003ca href=\"https:\/\/www.aimtechnologies.com\/support\/software\/downloads\" title=\"AiM Technologies Race Studio 3 Software Download\" target=\"_blank\"\u003eRace Studio 3\u003c\/a\u003e\u003c\/td\u003e\n\u003ctd style=\"text-align: center;\"\u003e\u003cbr\u003e\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\n\u003c\/table\u003e","brand":"AiM Accessories","offers":[{"title":"Default Title","offer_id":283349448,"sku":"SOLO-K2-L","price":43.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_solo2_DLODBIIexternalpowercable_00_1.5x.webp?v=1760089106","url":"https:\/\/www.aimshop.com\/pl\/products\/aim-solo-2-dl-obdii-external-power-connector-cable","provider":"AimShop.com","version":"1.0","type":"link"}
