1 z 5
Aim Tyre Temperature Sensor Kit
SKU: S-TT-SK
Normalna cena
£485.00
£582.00
INC VAT - UK only
Normalna cena
Cena sprzedaży
£485.00
Normalna cena
£485.00
£582.00
INC VAT - UK only
Normalna cena
Cena sprzedaży
£485.00
Infrared Tyre Temperature Sensor Kit
The Aim Tyre Temperature Sensor Kit has been specifically designed to measure the surface temperature of your tyres.
Provides important chassis tuning information
Compatible with MyChron 5 & 6
Connection via CAN
One status LED
Free analysis software
Four temperature sensors
Two 4 pin 712-719 patch leads 1m
Two 712-719 4 pin patch leads 2m
Why Choose The Aim Tyre Temperature Sensor Kit
The Aim Tyre Temperature Sensor Kit is the ultimate kart temperature kit to measure the tyres' surface temperature, which provides essential information for kart chassis tuning, tyre exploitation, and driver behaviour. The sensors, with a 35-degree field of view, measure temperatures between -20 and 120 degrees and provide a 0-5V output signal.
The kit comes supplied with an IR temperature controller, power cable, 4 x tyre temperature sensors and all connection cables.
Connection
The Tyre Temperature Sensor Kit doesn't need any configuration. Once connected to the MyChron Lap Timer, the information is automatically recognised by the system and data sampled can be downloaded with Race Studio 3.
To view the sampled data on your MyChron display, you will need to create a custom page and set the visualisation of sampled data on it.
Above is an example of devices that you can add to your system to enhance your racing performance. Expansions can include products like SmartCams, MyChron Expansion, spare Tyre Temperature Sensors, 712-719 4 pin patch leads and more.
Tyre Temperature Sensor Bracket Kit
The Aim Tyre Temperature Sensor Bracket Kit is available to help with the mounting & installation of the tyre temperature sensors. Please see the images in the User Guide for complete installation instructions.
Analyse with Race Studio 3
With Race Studio 3, you can analyse all data recorded by the Tyre Temperature Sensor Kit and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performance.
  • Connection to MyChron 5 & 6 via IR Temperature Controller
  • Output signal: - 0-5V
  • Field of view: 35°
  • Temperature range: -20°/120°C
  • IR temperature controller dimensions: 127.6 x 32 x 39mm
  • Sensor dimensions: 26.6 x 17.2mm
  • Sensor cable length: 250mm
  • IR temperature controller cable: 400mm
  • IR Temperature Controller
  • Four Tyre Temperature Sensors
  • Two 4 pin 712-719 patch leads 1m length
  • Two 4 pin 712-719 patch leads 2m length
Connection via CAN
One status LED
Connection
