1 z 4
K series keypads - K6 / K8 / K15
SKU: k6
Normalna cena
£185.00
Normalna cena
Cena sprzedaży
£185.00
K6/K8/K15
The CAN-Bus Keypads Series
Compact, Fully customizable, water and dust proof
The K6, K8 and K15 are compact keypads based on CAN-Bus protocol.
The devices are water and dust resistant and can be installed both inside and outside the cockpit. They are fully customizable and proposed with a wide range of interchangeble inserts.
The keypads will enable you to have your very own selected buttons at your fingertips. Available in 6, 8 and 15 key keypads.
Reconfigurable buttons Programmable RGB LEDs
LED backlit rings and icons Momentary, toggle and multi-status
2 blinking mode Wide range of inserts
CAN-Bus system compatible Vertical or horizontal mount
Status restore option
The Push buttons can be:
MOMENTARY
  • The pushbutton status is ON when the pushbutton is pushed.
TOGGLE
  • The pushbutton status changes from ON to OFF every time the pushbutton is pushed.
MULTI-STATUS
  • The pushbutton value changes from 0 to a MAX value every time the pushbutton is pushed.
RGB LED's
RGB LEDs are the best choice in low visibility conditions. Every pushbutton can be enlightened in 1 of 8 different colors, solid or blinking, according to the configuration defined by the user.
  • K6 PushButtons: 6 programmable Keys
  • K8 PushButtons: 8 programmable Keys
  • K15 PushButtons: 15 programmable Keys
  • Backlight: RGB with dimming option
  • Connection: AiM CAN 5 pins Binder 712
  • K6 Dimensions: 97.4 x 71.4 x 24 mm
  • K8 Dimensions: 127.4 x 71.4 x 24 mm
  • K15 Dimensions: 157.4 x 71.4 x 24 mm
  • K6 Weight: 120g
  • K8 Weight: 150g
  • K15 Weight: 250g
  • Waterproof: IP67
Remote Button CAN Interface Pro Keypad
  • Your choice of Aim CAN Expansion Keypad
  • Your choice length for the Male 5 Pin CAN Cable
  • USB Cable For Aim EXP CAN Keypad
K6/K8/K15
MOMENTARY
TOGGLE
MULTI-STATUS
RGB LED's
Technical Specifications
  • K6 Weight: 120g
  • K8 Weight: 150g
  • K15 Weight: 250g
  • Waterproof: IP67
Whats in The Box
