1 z 12
Remote Button CAN Interface Pro Keypad - 4, 6, 8, 10, 12 & 15 Key Keypads
SKU: RBI-B4-PRO
Normalna cena
£240.00
Normalna cena
Cena sprzedaży
£240.00
12 KEY AND 15 KEY CAN KEYPADS SOLD FROM 14/06/2023 WILL USE V2 PROTOCOL
*Please be aware that our PRO Keypads will require a more complex configuration than our Standard CAN Keypads but will add more customisability and features. If you would like to use the easy configuration method built into Race Studio 3, you must buy our Standard CAN Keypad.
The remote button interface keypads will enable you to have your very own selected buttons at your fingertips. Available in 4, 6, 8,10,12 and 15 key keypads.
Configurable channels Multicolour indicator rings
CAN bus compatible keypad LED status configurable
LED-backlit icons Vertical or horizontal mount
CAN Interface Keypad
The AiM remote button CAN interface keypads will enable you to have your very own selected buttons at your fingertips. The keypads are designed to a high standard to the highest standards for the harshest motorsport conditions. The keypad can withstand the cleaning of pressure washers and holds an IP67 rating, making them immune to water, mud, soil, sand, oil, chemicals.
The Pro keypads are available in 4, 6, 8, 10,12,15
Easy to Read
The keypads feature bright LED indicators, making them easy to read in any situation. The multi-coloured LED status rings allow you to set specific colours to your requirements.
With an extensive range of laser-etched inserts available, you can customise your keypad the way that's right for you, Lights, Heating & Fans; parking, the list is endless.
Please Note:
The keypads come blank with no inserts. We have an extensive range available; see the optional extras at the top of the page. Also, the lights on the keypads are for visual effect to show you how the keypad could look.
  • Remote Button CAN Interface Pro Keypad
Easy to Read
Please Note:
Technical Specifications
Whats in The Box
