{"product_id":"second-life-otk-kart-non-contact-throttle-sensor-kit","title":"Second-Life OTK Kart Non-Contact Throttle Sensor Kit","description":"\u003cdiv id=\"shopify-section-template--18875373125734__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e\n\u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eOTK Throttle Sensor Kit\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe Complete OTK Kart Non-Contact Throttle Sensor Kit is designed specifically for OTK chassis karts, providing precise, reliable throttle position data without the wear and tear of traditional contact sensors.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--18875373125734__rich_text_6xXAMV\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eWhy Choose the Complete OTK Kart Non-Contact Throttle Sensor Kit\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe Non-Contact Throttle Sensor Kit is tailored for OTK karts, so installation is straightforward and the fit is reliable. By adding throttle position to your data set, you unlock deeper analysis and more targeted driver development, which are key advantages in competitive kart racing.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--18875373125734__rich_text_i7YzQB\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eHow the Non-Contact Throttle Sensor Works\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe Complete OTK Kart Non-Contact Throttle Sensor Kit uses a non-contact sensor to measure the position of the throttle pedal. Instead of relying on a physical wiper or potentiometer, it detects throttle movement magnetically, which means there’s no direct mechanical contact inside the sensor. This makes it highly durable and resistant to the vibrations and harsh conditions typical in kart racing. The magnets mount to the pedals and the sensor to the kart, with no messy wires getting in the way, and it gives an exact indication of the pedal position, measuring its travel and shows all values in percentage in a 0 to 100 range.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e","brand":"Second-Life","offers":[{"title":"Default Title","offer_id":45631808471142,"sku":"424242","price":128.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/CompleteOTKKartNon-ContactThrottleSensorKit.png?v=1779096115","url":"https:\/\/www.aimshop.com\/pl\/products\/second-life-otk-kart-non-contact-throttle-sensor-kit","provider":"AimShop.com","version":"1.0","type":"link"}
