AiM SmartyCam 3 Bullet Camera Replacement Motorcycle
SKU: SOLO2-K-SUZ-SM-GPC-SM-CAM-GP-2
- Normalna cena
- £2,060.00
- Normalna cena
- Cena sprzedaży
- £2,060.00
- Cena jednostkowa
- za
+ VAT (tylko Wielka Brytania)
Suzuki GSX-R 1000/750/600 AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
The Suzuki GSX-R 1000/750/600 plug & play kit combined with the Solo 2 DL and SmartyCam 3 GP gives you the ultimate track day experience.
Database with more than 4,000 tracks worldwide | Suzuki ECU connection cable |
This ultimate track day kit has been specifically designed for Suzuki bikes. The kit includes a plug & play interface cable and bracket for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Suzuki ECU will give you all the engine performance information you need to help improve your driving performance.
SmartyCam 3 GP Features:
GSX-R 1000 L7 - 2017 onwards | GSX-R750 - 2006-2019 |
GSX-R600 - 2006-2022 | GSX-R1300 Hayabusa Gen.2 - 2008-2016 |
Powerful Combination
The Suzuki GSX-R 1000 L7 ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
SmartyCam 3 GP
Automatic Start/Stop
Suzuki GSX-R 1000 L7 AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
- Display: Graphical
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
- SmartyCam 3 GP
- CMOS sensor: Global Shutter
- Video Out: 3G-SDI
- External power: 9-15 Volt
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Body: Anodised Aluminium
Below is the pinout drawing for the Suzuki GSX-R 1000 L7 plug & Play connection cable.
- Solo 2 DL
- Power cable with AC adapter
- SmartyCam 3 GP - Bullet Cam
- External CAN cable 2m
- External power cable
- Suzuki Plug & Play connection cable
- 1 Bracket
- 1 toothed washer
- 1 rubber dowel
The Suzuki GSX-R 1000/750/600 plug & play kit combined with the Solo 2 DL and SmartyCam 3 GP gives you the ultimate track day experience.Key Features :
This ultimate track day kit has been specifically designed for Suzuki bikes. The kit includes a plug & play interface cable and bracket for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Suzuki ECU will give you all the engine performance information you need to help improve your driving performance.SmartyCam 3 GP Features:
The plug & play cable currently fits the following Suzuki bike models:GSX-R 1000 L7 - 2017 onwards | GSX-R750 - 2006-2019 |
The Suzuki GSX-R 1000 L7 ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated.
SmartyCam 3 GP
- GPS: 10 Hz
- Memory: 4 GB
- SmartyCam 3 GP
- Video Out: 3G-SDI
- Solo 2 DL
- 1 Bracket
- 1 toothed washer
- 1 rubber dowel
