10 Channel CAN Wireless Wheel Button Plate
£695
10 Channel Wireless Button Plate. Our 10 channel wireless system allows you to have push-button controls at your fingertips.. Features:...
Features:
  • CAN Wireless System
  • 8 Digital Push Buttons
  • CR2 Lithium Battery
  • Two 12 position analogue inputs
  • Free Race Studio 3 Download
CAN 10 Channel Wireless System.
Our AiM 10 Channel wireless system allows you to have push-button controls at your fingertips. Whether you have a detachable steering wheel or would just like to avoid the need for an unreliable coiled wire connection from your steering wheel to the dashboard.
The system uses a wireless (RF) connection between the wheel plate transmitter and CAN receiver; this compact receiver is neatly installed behind your dashboard and attached to your AiM CAN device directly using the supplied Binder harness.
Please Note: Steering Wheel NOT INCLUDED
10 Channel CAN Wireless Wheel Button System
The 10 channel CAN wireless wheel button system has eight digital push buttons along with two rotary 12 position analogue inputs, which can be used for adjusting the ECU engine map/cal setting, ECU traction control settings or theatre selection settings and much more, giving you a total of ten channels all wirelessly controlled from your steering wheel.
Our AiM CAN transmitter and wheel plate assembly bolts straight onto your steering wheel hub and fits all standard bolt patterns on 6 x 70mm, 6 x 74mm and 3 x 50.8mm PCD steering wheels. Supplied with a standard CR2 Lithium battery, with a guarantee lifetime of 3 years or 50,000 miles road time. There is no need to worry about a flat battery with our smart system as the battery voltage is regularly transmitted to the CAN receiver and forwarded to your AiM device, giving you around 30 days notice if it needs to be replaced.
With unrivalled RF communications between transmitter and receiver, tested to withstand even the harshest EMI that can be generated within your car, so you will never lose connection with your wheel.
Use our PDM and Race Studio 3 Software to control the behaviour of the momentary push buttons to act as simple latching  switches or more complex control.
Unlock your potential
Our mission is to help enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn.
AiM Product Video
Transmitter Components
  • Button Plate Front: Matt Black, Textured Acrylic
  • 176 x 154mm
  • Battery Housing: ABS-UL94-V0
  • 54 X 38 X 23mm external
  • CR2 3V Lithium
  • >2000 hours active use
  • Pushbuttons: IP67 momentary
  • Assembly: 10-channel: 285g 176 x 154 x 49mm
  • PCDs Supported: 6 x 70mm, 6 x 74mm, 3 x 50.8mm
  • Button Plate with 8 Push Buttons and Two 12 position analogue inputs
  • 10 Channel Receiver with Connection Harness
  • CR2 Battery
  • Decal Sheet
