AiM 22 Pin Deutsch Harness MXS, MXP, MXG, MXL2
Harness with Deutsch motorsport connectors to suit AiM MX Series.
Key Features:
This 90° harness plugs into the 22-pin connector on either the MXL2, MXG,MXS,MXP. Several of the advanced functions rely on this harness, which is not included in the standard kit. |
The AiM 22 pin harness will provide access to the following functions: Analog sensor channels 5, 6, 7, 8 |
Please Note: The standard harness that comes with the AiM MXG, MXS, MXL2, MXP allows 4 inputs. If you would like more inputs for your race data then add this harness to your kit. |
Adding analog sensors greater than 4 - The standard harness will allow up to 4 analog channels (sensors) - This may be (1) Water Temperature, (2) Oil Temperature, (3) Oil Pressure (4) Brake Pressure. Using this 22 pin Deutsch harness you can now add four more analog channels (sensors). Like (5) Steering Angle, (6) Throttle Position, (7) Gear Box Temperature, (8) Differential Temp. Another way we see this cable used is independent shock travel (all corners) or engine oil temperature pre-cooler and oil temperature post-cooler. |
Unlock your potential |
Please see Technical Sheet in Downloads
