Skip to product information
1 of 3
Aim 37 Pin Deutsch Harness with 1 Thermocouple MXS, MXP, MXG, MXm
SKU: H37-ST-V02573040
£375.00
£375.00
The Aim 37 pin Deutsch Harness with one thermocouple connector to connect a K-Line type sensor.
Suitable for MXS, MXP, MXG, and MXm Digital output
 37 pin harness One thermocouple connector
 37 pin Harness with One Thermocouple Connector for the MX Series
The Aim 37 pins harness has been designed with one thermocouple connector, this will enable you to connect a thermocouple sensor to your device.
The Aim 37 pins Deutsch harness functions are listed below:
Digital wheel speed channel 1
CAN expansion
Power+
Ground-
CAN ECU connection
K-Line connection
Please Note: If you wish to add extra race data then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab.
Also available is a 37 pins Deutsch harness with two thermocouple connectors, available in the Accessories Tab.
  • 7 non-ended cables - See table in Downloads Tab
  • Female Thermocouple Connector - See table in Downloads Tab
Aim 37 Pin Deutsch Harness MXS, MXP, MXG, MXM
  • 37 pin Deutsch Harness
The Aim 37 pins harness has been designed with one thermocouple connector, this will enable you to connect a thermocouple sensor to your device. This harness can be used to replace a damaged harness or for a second vehicle installation when sharing a dash logger.  The Aim 37 pins Deutsch harness functions are listed below: Analogue sensor channels (sensors) 1, 2, 3, 4
CAN expansion
Power+
Ground-
CAN ECU connection
K-Line connection Please Note: If you wish to add extra race data then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab. Also available is a 37 pins Deutsch harness with two thermocouple connectors, available in the Accessories Tab.
