AiM 37 Pin Deutsch Harness with 2 Thermocouples MXS, MXP, MXG, MXL2
£300.00
Harness with Deutsch motorsport connectors to suit AiM MX Series.
Key Features:
  • Suitable for MX series
  • 37 pin harness
  • 2 Thermocouples
  • Free race studio 3 download
This 37 Pin Deutsch harness has been designed to connect K type thermocouple sensors to your device.
Having a 37 pin connector on the dash and break out connections for 12v+, 12v CAN ECU connection, K-Line, analogue sensor channels 2, 3, 4, 1, digital wheel speed, optical lap timing sensor input and CAN expansion, USB.
Channel 1, 2 ending in a mignon connector.
For use when you move your primary AiM Dash Logger from your primary vehicle to your back-up vehicle. Also commonly used to move your AiM system from your race car to your champCar or Lemons car.
By using a few extra cables you can have your complete AiM data system in more than one vehicle with minimal effort.
The AiM 37 pin standard Deutsch harness for MXS, MXP, MXG, MXL2 functions are:
Analog sensor channels (sensors) 1, 2, 3, 4
Digital wheel speed channel 1
Optical lap timing sensor input
CAN expansion
Power+
Ground-
CAN ECU connection
K-Line connection
Channel 1, mignon connector
Channel 2, mignon connector
Please Note: If you wish to add extra race data then you will need the 22 Pin Deutsch Harness. This will add four more analog channels (sensors).
Unlock your potential
Please see Technical Sheet in Downloads
