AiM 37 Pin Harness.
Harness with Deutsch motorsport connectors to suit AiM MXS, MXP, MXG, MXL2, MXM.
Key Features:
The 37 pin harness is the standard harness which can be used with the MXS, MXP, MXG, MXL2, MXM It has 4 input channels, a GPS input and a CAN expansion channel. It has a built in USB so you can download your data and use that data to improve your performance. In addition to the standard harness you can purchase a 22 pin harness to give you additional data.
Optional 37 pin harness is used to provide the following additional channels / advanced functions.
37 Pin Harness
