AiM 6" TFT PDM Road Icons Display Screen
The Aim 6" TFT PDM Road Icons Display Screen is specifically designed to fit the PDM08 and PDM32 Power Distribution modules.
Please Note: The PDM 6" and PDM 10" Road & Race Dash Displays are only compatible with the AiM PDM08 & PDM32.
Housed in an anodised billet aluminium case, the PDM display screen is designed to handle the rigours of Motorsport and includes a complete professional data logger and internal dash controller.
Key Features:
PDM08 & PDM32 Connection Example
These displays can also double up as a reversing mirror by using our separate camera, which is sold separately. Ideal for cars with limited rear vision. Up to two cameras can be added for both front and rear views. The mirror camera connects to the PDM through the 5 pin binder connector. |
- Display : 6” TFT Road Icons
- Resolution :800x480 pixels
- Contrast :600:1
- Brightness :700cd/m2 - 1,100 Lumen
- Ambient light sensor :Yes
- Status information LEDs :5
- Shift Lights LEDs :10
- Body :Anodized Aluminum
- Pushbuttons :Metallic
- Connectors :LVDS Link 4 Pins Rosenberger male connector
- Dimensions :189.6 x 106.4 x 24.9 mm
- Weight :640 g
- Power consumption :150 mA
- Waterproof :IP65
AiM 6" TFT PDM Road Icons Display Screen only
