Aim 712-719 Male to Female 4 Pin Patch Lead Kart
SKU: P-712-719-5-V02PCB05BTXG
- £40.00
- £40.00
The Aim 712-719 male to female 4 pin patch lead extends the original wiring harness, e.g. when fitting analogue sensors.
712-719 patch lead | 4 pin male to female |
Extends wiring harness | Various lengths available |
The Aim 712-719 male to female 4 pin patch lead extends the original wiring harness, e.g. when fitting analogue sensors. Available in different lengths to suit your application.
Use this patch lead to connect your EVO4/EVO4S logger or Channel Expansion device to various analogue sensors. You can also extend the cable length further by using a 719-719 patch lead.
- 712-719 4 pins Male to Female Patch Lead
- 50cm
- 100cm
- 150cm
- 1 x 712-719 Male to Female 4 Pin Patch Lead
The Aim 712-719 male to female 4 pin patch lead extends the original wiring harness, e.g. when fitting analogue sensors.Key Features :
The Aim 712-719 male to female 4 pin patch lead extends the original wiring harness, e.g. when fitting analogue sensors. Available in different lengths to suit your application.Use this patch lead to connect your EVO4/EVO4S logger or Channel Expansion device to various analogue sensors. You can also extend the cable length further by using a 719-719 patch lead.
- 50cm
- 100cm
- 150cm
