Free Shipping Next Day Delivery +44 (0)1782 393843 Shop now, Pay Later
AiM 8 Button Wireless Steering Wheel Plate
£575.00
Wireless Button Plate.
AiM 8 channel wireless system allows you to have push-button controls at your fingertips.
Features:
  • CAN Wireless System
  • 8 Digital Push Buttons
  • CR2 Lithium Battery - 50,000 miles usage
  • 30-day low battery warning
  • Integrates with most CAN devices
  • Simply bolt between wheel & bos
  • 3 Year Guarantee
  • Free race studio 3 download
CAN Wireless System
Wirelessly implement in-vehicle commands in a fraction of the time with up to 8 instant steering button controls.
Use features such as; flash lights; sound horn or indicate with our instant steering wheel to your car.
Achieve optimum driver convenience by no longer having wire connections from your steering wheel to your car.
Race faster, harder and safer with push button controls at your fingertips, combining minimum driver distraction with maximum ease of use.
The steering wheel plate is slim and lightweight, fitting simply between your wheel and wheel bos.
The system integrates with most CAN devices, including mainstream dashboards,ECUs, PDUs and data loggers.
It comes with eight fully configurable automated steering controls, 50,000 miles of per battery and a 3-year manufacturer guarantee.
Please Note: Steering wheel not included. Stickers also are for visual display to show you how the wheel plate could look. Please see optional extras to purchase sticker sheets.
8 Channel Wireless Wheel Button Plate
The 8 channel CAN wireless wheel button system has eight digital push buttons and transmitter which bolts straight to your steering wheel hub and fits all standard bolt patterns.
The button plate is suitable for most standard bolt patterns on 6x70mm, 6x74mm and 3x50.8mm steering wheels. Supplied with a standard CRS lithium battery that has a guaranteed lifetime of 3 years or 50,000 miles.
You don't need to worry about the battery going flat, with the smart system the battery voltage is regularly transmitted to the CAN receiver and then forwarded to your AiM device that gives you around 30 days notice if the battery needs to be replaced.
With unrivalled RF communications between transmitter and receiver, tested to withstand even the harshest EMI that can be generated within your car, so you will never lose connection with your wheel.
Use our PDM and Race Studio 3 Software to control the behaviour of the momentary push buttons to act as simple latching switches or more complex control.
Unlock your potential
Our mission is to help enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn.
Transmitter Components
  • Button Plate Front: Matt Black, Textured Acrylic
  • 176 x 154mm
  • Battery Housing: ABS-UL94-V0
  • 54 X 38 X 23mm external
  • CR2 3V Lithium
  • >2000 hours active use
  • Pushbuttons: IP67 momentary
  • Assembly: 8-channel: 265g 176 x 154 x 33mm
  • PCDs Supported: 6 x 70mm, 6 x 74mm, 3 x 50.8mm
8 Channel CAN Wireless Wheel Button Plate
  • Button Plate with 8 Push Buttons
  • 8 Channel Receiver with Harness
  • CR2 Battery
