Skip to product information
1 of 3
AiM Brake Pedal Position Sensor Linear Travel Potentiometer 10mm
SKU: S-B-LP-K
£85.00
£85.00
The short linear stroke 10mm displacement potentiometer for measuring brake pedal movement.
Brake pedal sensor 10mm displacement
4 pin 719 binder connection
The short linear stroke (10mm) displacement potentiometer is ideal for measuring brake pedal movement. A pedal travel sensor such as this can be simpler to install in many vehicles than plumbing a pressure sensor in the brake line.
The compact sensor body measures just 3/4" (19) OD X 1 3/8" (35mm) long overall (more miniature plunger). Two 1/4" (6mm) mounting holes are located at 1.34" (34mm) centre to centre.
Ideal for high precision data acquisition or control systems.
  • Brake Pedal Position Sensor Travel Pot 10mm
  • 1 x Brake Pedal Position Sensor
