AiM CAN Connection Channel Multiplier
£190
The Channel Expansion hub adds up to four configurable analogue (or two digital and two analogue) channels without...
The Channel Expansion hub adds up to four configurable analogue (or two digital and two analogue) channels without occupying or modifying any existing system channels.
The Aim Channel Expansion is a compact CAN device providing virtually endless data acquisition system expansion options.
By using advanced CAN technology, wiring is simplified from four cables into just a single connection, thereby reducing possible and unnecessary points of failure. It is also possible - via Data Hub - to connect to the Master as many Channel Expansion as needed.
Aim Channel Expansion connections
Dimensions: 123x30x23 mm
Weight: 97 g
Sampling Frequency: Programmable up to 100 Hz (depending on sensors)
