AiM Car Data Hub 2X CAN Connection Multiplier
£50
AiM Two Way Data Hub AiM Data Hub two hub connection multiplier works as an interface between AiM...
AiM Data Hub two hub connection multiplier works as an interface between AiM loggers and peripheral sensors.
Key Features:
  • Two way Data Hub
  • Free race studio 3 download
The AiM Two Hub Data Logger
The data hub 2x CAN connection multiplier is used for the acquisition of all the essential data you need to evaluate your performance.
The data hub is an external expansion module that allows you to increase the range of data available for analysis.
The acquisition of all the data you need to evaluate your cars performance needs the connection of many accessories to your data logger.
This implies the presence of a great number of cables but the Data Hub takes all the information you need sent to the logger with just one cable, minimising wires overall.
More Data Hubs can be connected in sequence in order to increase the number of peripherals which can be connected.
AiM Product Video
  • Dimensions: 70x30x23.5mm
  • CAN cable length: 40cm
  • Source Cable Length: 165cm
  • Weight: 86g
Search compatible ECU's by manufacturer supported by AiM
Click here >
