AiM Car Fuel Level Sender With AiM 4 pin 719 Binder
£189.00
The fuel level sender outputs a voltage in proportion to the fuel level in your tank.
Key Features:
The fuel level sender with (719 plug) records the fuel level, allowing you to determine how much fuel you need for a session or race.
If shortening the length of the fuel sender is required, ensure the length is 10mm short of the full depth of the tank but cannot be cut shorter than 200mm from where the gasket sits.
Please See Technical sheet in Downloads for further information on this product. |
AiM Technologies are committed to supplying, professional engineers quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding Motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the market place today. |
Unlock your potential |
- Fuel Types: Typically Diesel, Biodiesel, Kerosene and Petrol (Water is not measurable)
- Probe Length: Min 200mm max 540mm
- Mounting: SAE5 Hole
- Supply Voltage: 10-32v DC
- Supply Current: 28mA @ 12v DC
- Supply Protection: Over voltage 80v DC for 2 minutes, Reverse Polarity
- Signal Output: 0-5v DC or 5-0v DC, 20mV steps, Max 10mA source
- Connections: 500mm long with either flying leads or an AiM plug fitting
- Accuracy: + 3% of depth @ 20°C
- Enclosure: 30% Glass filled Nylon
- Enclosure Bush: Polypropylene
- Internal Electrode: Aluminium
- Sensor Tube: 316 Stainless Steel
- Internal Spacers: Polyropylene
- End Plug: PTFE
- Wetted Seals: Viton (FKM) & Nitrile
- Gasket: Nitrile
- Cable: Polyurethane
- Sealing IP67 (Assuming suitably sealed cable breakout)
- Operating Temperature: -20°C to 85°C
- Shock: 50g, 6.3ms
- Vibration: 9.7g BS EN 60068-2-64-1993
- AiM Car Fuel Level Sender With Aim Plug 719 Cable
