AiM Cobra Motocross Unprogrammed ECU Plug & Play Engine Control Unit
£480.00
AiM Cobra ECU Plug & Play Engine Control Unit
Cobra is the brand-new aftermarket plug & play ECU created by AiM, exclusively designed for off-road bikes. Thanks to its high technology 32-bit core, it represents an important step forward to improve the performance of your bike, without sacrificing reliability and smoothness.
This specific Cobra ECU is unprogrammed. It can be configured for any brand or model bike you require. You will need the UC Bridge Tuner to enable this process.
Once the unprogrammed Cobra ECU has been configured with a dedicated brand or model it can not be changed. You will be able to modify the maps written into the ECU but the brand or model which has been configured can not be changed.
Cobra Key Features & Advanced Strategies
Traction Control
Traction Control Strategy
Launch Control
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the Cobra ECU guarantees the precision of 1/10 of the degree: this means an accuracy within 0.8 uses for turning the spark ON!
Tuner License :
This is the Tuner that is required to configure the unprogrammed Cobra ECU.
Cobra ECU Connections
The Cobra ECU has 4 connectors :
2nd CAN Connector - Connect to the UC Bridge, to communicate with the PC.
3rd Connector - Connect to spare analogue inputs and a possible second injector.
Below shows a functional diagram of products that can be added to the Cobra ECU:
  • One low side driver (1 A)
  • Power consumption 150 mA
  • n. 1 33 pin male Connector
  • Body: PA6 + 30% glass fiber
  • Waterproof: IP67
  • Weight: 260g
  • ECU Cobra Control Unit
